Anyone have these air bags, Greg recommended the AirLift for me and he gave me the part number but I will have to order it from another retailer. The Firestone Air Bags are available locally and I was wondering if anyone who might have these are having problems. Greg's advice seems best to me.
2004 Smoke Color SE 4 X 4 Crewcab fully loaded with Off Road Package, Popular Pkg, Util Pkg, Big Tow Pkg, SplashGuards, Floor Mats,
I installed after purchase: *Dealer installation
Bug Deflector,
Wade Window Vent Visors
Westin Platinum Step Rails
Carriage Bolt Billet Grilles Upper and Lower
Stillen Dual Rear Straight Exhaust Part #509547*
K&N 77 Series Polished Alum Air Mod Kit #6012KP*
Trailmaster Front Coil Spring Leveling Kit #NL220*
Husky rear floor mats
TruxedoTonneau Lo Pro Cover
Prodigy Brake Controller
IPOD Interface Kit
Firestone Ride Rite Air Bags part #2355
Towing on vacations: 2008 Keystone Hideout 28'
Model 27B Travel Trailer with Eaz-Lift 1000/14000 WD and Robins Sway Bar.
DR Rear shocks
Future Mods: Front SAWs coilovers or Bilstein Adjustables
I had the RideRite air bags installed a couple of years ago, and they're probably the best money that I've spent on the truck. They work - period. If you get the ones without the onboard compressor, have them run the valve stem through your license plate attachment hole, for easy access........
When you're not loading down the truck, run the bags with about 5-10 psi in them, and they won't affect your ride quality.
'04 Titan Galaxy LE KC 4x4
Off Road & Big Tow Packages
Build Date: 06/14/04
Buy Date: 06/25/04
Wade In-channel Vent Visors
PRG's Front Leveling Kit
P/A 3" Body Lift Kit
Bushwacker Fender Flares
Billet Grille
MagnaFlow Single Side Exit
Nitto Dune Grappler A/T (315/70/17)
Firestone RideRite Airbags
I have the firestone, and love them. I have the onboard compressor also. I have had them on for over 2 years with no trouble, I don't find the ride has changed as long as I keep them at or below 10 psi. I also think they are more durable than the other bags available.
Got em and love them also,I went without the onboard compressor.I bought a 12V portable compressor I keep in my bed storage area.When needed I pull it out and plug it into the power outlet in the bed.
I went against the mounting instructions and put a "T" connector between the two lines so I wouldn't have to worry about balancing the two bags independently.I ran the air hoses throught the frame rails for a really clean look and installed the valve stem on the bracket that holds the 7 pin connector on my tow hitch.
When making my decision,I compared the Ride Rite's to the Airlift's side by side,the Ride Rites seemed much more heavy duty.Note also if your truck is lifted you can purchase "cans" which are round steel spacers to mount under the bags that correspond with the height of your lift blocks on the leaf springs
I have the air lifts and love them.. I run individual lines to the bags and have the charge valves are in the side storage box. The compressor would be nice, but like Mike I just have a small 12 volt compressor to air up as needed.
__________________ '05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust. Towing WW FS2300 Toyhauler and all the toys.
My first post here, just have a quick question. I have been looking at either air bags or the Roadmaster Active Suspension system. Need opinions on which to go with. Any input will be greatly appreciated.
__________________ CKD
2008 TITAN 2WD LE
majestic blue
I too have the ride rites and am very pleased. I also have the on board compressor which I got at the suspensionconnection.com. The airbags were about 260 and the the compressor was on sale for about 180 and this was about 2 or 3 years ago. A friend of mine helped install and we did it in abou 3 1/2 hours. Either way you'll be happy.
04 CC SE Smoke 4x4 DVD OR BT. AEM Brute Force CAI, Magnaflow Muffler, 2* Advance, Firestone Airbags, Mag-Hytech Diff cover, Stillen front & rear sway bar. Stainless rocker panels. Pull-Rite 12k and Prodigy controller for the 2007 Cougar 278RKS. Amsoil throughout!
I just ordered mine from jcWhitney $250 less $45 (promo code i found online) they should be here thurs/fri can't wait to put em on. Should help alot with the sagging when pulling my work trailer.
05 Titan 4x4 6in lift 35x12.5r18 Nitto's____05 Pathfinder 4x4 305/70r16 on 16x8 NO LIFT
Has anyone found that the compressor your buying (with the full kit) is capable of airing up tires or filling an on board air tank? I plan to run OBA on my Titan but would like 1 compressor to handle all air tasks.
Thanks everybody for the responses, I decided and went ahead and purchased the Firestone Ride Rite part number 2355. Suspensionconnections web site had them listed for $275. They cost me $319 and I bought the kit here to support our local business. I pick them up tomorrow morning.
