Old 04-02-2008, 02:55 PM   #1 (permalink)
TitanTeamRoper's Avatar
Send a message via Yahoo to TitanTeamRoper
Load controller II placement
Does anyone have air lift airbags with load controller II installed in their trucks? If so where did you put the switch/gauge?
I'll be installing both this weekend and don’t have any clue where I should put the gauge.
2006 LE 4X4 Crew Cab Galaxy Black
Big Tow, OFF-Road, Nav, Sunroof
Current mods
2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
TitanTeamRoper is offline   Reply With Quote
Old 04-03-2008, 09:28 AM   #2 (permalink)
Re: Load controller II placement
no one has added the compressor
Current mods
Old 04-05-2008, 06:48 PM   #3 (permalink)
Nissanloyalist's Avatar
I have the firestone airbags w/ the compressor and it should be about the same size. I installed mine under the dash below the steering wheel and it is perfect there.
load-controller-ii-placement-air-guage.jpg  load-controller-ii-placement-truck-003.jpg
04 CC SE Smoke 4x4 DVD OR BT. AEM Brute Force CAI, Magnaflow Muffler, 2* Advance, Fitch Fuel Catalyst, Firestone Airbags, Mag-Hytech Diff cover, Stillen front & rear sway bar. Stainless rocker panels. Pull-Rite 12k and Prodigy controller for the 2007 Cougar 278RKS. Amsoil throughout!
Nissanloyalist is offline   Reply With Quote
Old 04-05-2008, 07:10 PM   #4 (permalink)
Thanks for the pictures; I think I will be putting it into the bottom of my center console. But my concern now is where to put the air compressor. According to the user manual the compressor is NOT moisture & splash resistant, but NOT WATER PROOF. I'm guessing that the first not has to be a typo, but I’m not sure. I did some searching and found this thread
Airlift AirBags.
He mounted his in the rear of the truck, but he has a different compressor, he only got Load Controller I which they don’t make anymore
Current mods
Old 04-05-2008, 09:34 PM   #5 (permalink)
I mounted mine under the rear seat behind my sub box. The firestone compressor stated that you have to be within 12 to 16 inches or something like that from the battery or power source. I used my the power line for my amps to power the compressor. I have 4 guage to my amps and this worked out well for me. Plus now the compressor is inside the cab and no worries about the elements. Plus this way I only had to put one air line through the firewall.
Old 04-06-2008, 12:41 AM   #6 (permalink)
RobKar's Avatar
I have Airlift and my compressor is on the "hump" under and in back of the drivers side passenger seat.. Lift up the back seet and you will know where I mean.
As for the gage I installed this in the center console at the back with the gage and switch pod attached to the top and back of the box.
Sorry no pictures because I am in Hong Kong/ China for another week or 2.
TrollopInTraining™
2005 CC LE
My wife thinks I spend to much on my truck!!
My Train Horn <-- Listen
RobKar is offline   Reply With Quote
Old 04-19-2008, 08:19 PM   #7 (permalink)
TitanCrewCC's Avatar
I installed the ride rite system- well half of it- The compressor is in mounted behind the seat in the crew and the switch gauge I mounted in the glove box. My only problem is that I have the truck lowered 2" deaver lowering springs and I didn't know the bags wouldn't fit on a lowered application (totally my fault) so I'm leaving the compressor in - working on an alternative for the bag brackets. They are just too tall- I could mount them but they would defeat the purpose of having the truck lowered. I tow a 12x7 enclosed trailer with my bikes so I for now I'm running air shocks in the rear to overcome the squatting.
TitanCrewCC is offline   Reply With Quote
Old 04-20-2008, 09:32 AM   #8 (permalink)
GGattorr's Avatar
I attached my Load Controller II right behind my Cold Air Intake onto the metal box that is my Cold Air Intake housing.
Here is the thread with pics
http://www.titantalk.com/forums/tita...-installed.htm
2004 Titan 4X2 SE w/o BT Deep Water POP Pkg
20" Halo Wheels w/305/50R20 8ply A/T Tires, K&N CAI, Flowmaster True Dual 3" Exhaust, Front End Leveling Kit, Class IV Hitch, Chrome Bug Shield, In Channel Ventvisors, Tinted Windows, ARE Tonneau Cover, Chrome Taillight Covers, Chrome Tailgate Handle Cover, Slash Guards, Bedliner w/ Bed Extender, PML Diff Cover, and Ride Rite Air Bags w/Level Commnd II Air Compressor, Prodigy Brake Controller, and Equal-I-Zer Hitch
SEMPER FI
GGattorr is offline   Reply With Quote
Old 04-22-2008, 10:26 AM   #9 (permalink)
Burgy's Avatar
Send a message via AIM to Burgy
Link is broken.
Burgy
(Kevin)
08.5 Titan CC SE 4x4
Burgy is offline   Reply With Quote
Old 04-22-2008, 10:43 AM   #10 (permalink)
DID YOU BUY THE ONE SPECIFICALLY FOR LOWED TRUCKS?
HERE'S THE LINK BURGY
http://www.titantalk.com/forums/titan-towing-hauling/74458-ride-rite-air-bags-installed.html
BUT DIDN'T YOU INSTALL FIRESTONE, NOT AIRLIFT?
Current mods
E load VS. D load tire? Gonpostal Titan Suspension 1 12-19-2007 01:25 PM
Amp Placement Danthegreat1 Titan Visual & Audio Discussion 7 11-25-2007 01:26 PM
Sub placement in King Cab greg77 Titan Visual & Audio Discussion 12 05-26-2007 07:45 PM
LOC placement for RF t22a80 Titan Visual & Audio Discussion 3 08-16-2005 05:06 PM
Brake controller Placement rickaxe Titan Towing & Hauling 28 06-08-2005 08:28 AM
