Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Trailor lights - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 04-04-2008, 04:29 PM   #1
stryker759a
Trailer lights
I hooked the u haul up to the truck bout to move, and the only light working is the left turn signal. I checked the fuse it is good. The u haul guy probed it with this pointer that lights up if it is good or bad sorry not very mechanical. The top hole lights up which is the left blinker but the right and brake light and lights don't light up what should i check next.
stryker759a is offline   Reply With Quote
Old 04-04-2008, 04:47 PM   #2
yamaguy88
Re: Trailor lights
bad adapter maybe? ive been having problems w/ my running lights havnt figured it out yet.
yamaguy88 is offline   Reply With Quote
Old 04-04-2008, 04:54 PM   #3
loufish
loufish's Avatar
Re: Trailor lights
Where should I start...Oh yeah What year is your truck?
The batteries went out in my Cyrstel Ball...
Are you sure you checked all the fuses?
You might have a couple of fuses right out of the Body Control Module also...
PRG Performance Kit w/SAW's
Nitto Terra Gobblers on factory OR wheels
Born 9/2004
2002 Honda XR650R
Old 04-04-2008, 05:06 PM   #4
stryker759a
Re: Trailor lights
MY truck is an 04 se. I found the fuse in the engine compartment and the compartment in the passenger side but it didnt have anything to do with trailer.
Old 04-04-2008, 07:10 PM   #5
loufish
loufish's Avatar
Re: Trailor lights
Does your truck have the factory tow package?
There was a recall for part of the tow harness, you need to check for fuses inline below the steering column, behind the plastic...See the diagram.
Old 04-05-2008, 04:22 AM   #6
young dank
Re: Trailor lights
do you have all your relays? did you have the BCM recall performed? Is the Uhaul trailer grounded at both lights? then check underthe dash board and have nissan check it. let us know what was the cause.
I am a nissan employ, I will answer all your questions. I am also a good shade tree machenic.
///YOUR SIG IMAGE HAS BEEN REMOVED FOR BEING FRIGGIN' HUGE! PLEASE RESIZE TO 300X200PX OR LESS\\\
young dank is offline   Reply With Quote
Old 04-05-2008, 06:37 AM   #7
loufish
loufish's Avatar
Re: Trailor lights
Is it just me, or is this like the 10th time in the last few weeks with "no lights" thread topics?......
Do we need a "sticky" to cover basic trailer light diagnoses?
Old 04-05-2008, 09:21 AM   #8
Derwud
Derwud's Avatar
Re: Trailor lights
Yes!!!! with all of the wiring diagrams...
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 04-06-2008, 09:02 AM   #9
loufish
loufish's Avatar
Re: Trailor lights
Sounds like a good idea....I'd like one of the mods to weight in before such posting...
Old 06-05-2008, 12:51 PM   #10
Emptylili
Re: Trailor lights
Sounds like a good idea to me since I just spent the day testing fuses (finding none blown) and if I had not stumbled onto this thread while searching for a solution would still probably be scratching my head. Thanks to Loufish for posting of the wiring diagram for the "04 an the bit about the two fuses under the dash no where near the trailer brake connector. One is for left side and the other is right side turn & brake signal. When they blow you got only running lights on the trailer but everything works on the truck.
So btw. If you got the fuses under the dash does that mean the recall has or has not been performed? Thanks again.
Emptylili is offline   Reply With Quote
Old 06-05-2008, 09:08 PM   #11
loufish
loufish's Avatar
Re: Trailor lights
The two fuses are located in a small sub-harness that goes in between the BCM and the the original trailer wire harness from the BCM....Yes if the fuses/harness is there, the TSB has been completed...
User Name
Password
Travel trailor people in here please. BuckyBadger Titan Towing & Hauling 18 10-19-2007 03:29 PM
trailor hook up sresinger Titan FAQ & Howto Area 3 11-21-2006 09:40 AM
Trailor Plug Question bgraves Titan Parts & Accessories 4 06-14-2005 12:24 PM
trailor light hook up help Mrs Holmes Titan FAQ & Howto Area 10 06-13-2005 05:23 PM
Trailor wiring Nuckle Titan Towing & Hauling 7 08-28-2004 09:04 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
