Old 11-05-2007, 08:27 PM   #1 (permalink)
Tekonsha Prodigy Brake controller question.
Sorry if this has been beaten to death. I have a new 2006 Nissan Titan LE with tow package. If I understand it correctly, with the Tekonsha Prodigy controller and the Nissan harness that I can buy with it, all I have to do is plug the one end of the harness in to the plug under the left driver side dash, after I find it and the other in to the end of the controller, mount it and I am ready to go with no other wiring , etc.? I am also quite handy.
The guys at the RV place made it sound like it was quite complicated to install and would need to be done so professionally. When I look at things it seems pretty straightforward. Any advice would be appreciated.
Thanks
Mark
20shadow05 is offline   Reply With Quote
Old 11-05-2007, 09:00 PM   #2 (permalink)
Sftail1990's Avatar
Re: Tekonsha Prodigy Brake controller question.
Thanks
Mark
If it is the aftermarket pigtail that goes with the controller it is plug and play, if you are using the one that comes with the Titan from the dealership be careful of the wire colors, they do not match up with the controller. For a about ten bucks more you can just buy the one with the controller and it has the connectors on each end, no splicing in and worry there. You can also unplug the controller and take it out if you wish. Tell the boys trying to scam a buck or two to pack sand and save yourself the money and do it yourself. There are links to threads here that will show you where the connector on the Titan is, I believe it is tied up to the steering column. it shouldn't be an issue to find it.
Sftail1990 is offline   Reply With Quote
Old 11-06-2007, 06:34 AM   #3 (permalink)
Derwud's Avatar
Titan plug
Wiring Help
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 11-06-2007, 06:58 AM   #4 (permalink)
Quartz's Avatar
Very good advice. Do what Sftail1990 says and you will be fine. It took me about ten minutes to install the brake controller.
Old 11-06-2007, 07:01 AM   #5 (permalink)
thclimer's Avatar
Thanks
Mark
Mark,
Derwud has given you a great photo showing the location of the plug and if you want to do the wiring he has given you that as well. It really is an easy job. Don’t let those guys scare you into thinking it that’s complicated.
2006 LE KC 4X4 BT, Radiant Silver
Prodigy Brake Controller
Equalizer Hitch
Scan Gauge II
Firestone Air Springs
Bridgestone Dueler A/T Revo's
A.R.E. Z-Series Cap
thclimer is offline   Reply With Quote
Old 11-06-2007, 10:37 AM   #6 (permalink)
SirKeats's Avatar
i installed my prodigy in an 04 XE KC... the only model to NOT come with harness... and even THEN it was still easy. i used the wiring instructions found here and the splice in connectors. hardest part was deciding on where to route my wires (i'm picky and wanted a super clean install even under the dash where no one would ever see it anyway).
with your plug and play setup... there's no reason to not do it yourself. the rv guys are just trying to scam you out of your money.
SirKeats is offline   Reply With Quote
Old 11-08-2007, 01:55 PM   #7 (permalink)
Where is everyone mounting their brake controller? On my Honda Pilot the only good place made the controller really difficult to see.
Are there mounting holes?
gksmith is offline   Reply With Quote
Old 11-08-2007, 02:02 PM   #8 (permalink)
BuckyBadger's Avatar
Most install it near the right knee. No holes, use 3m tape or make your own holes. I have never hit my knee on it yet.
2007, 4x4,SE, Radiant Silver, BigTow, Bed Liner, Utilitrack, Utilitrack Bed Divider, Truxedo roll up, N-Fab Step bars,
6 disc changer/MP3, Capt Chairs. Michelin Cross Terrain, Born on Nov 06
FOB tailgate mod, Fog lights, Tailgate open light Mod, hard wire Garmin 7200, Hard wire back up camera Monitor, Wet Okole seat covers
2007 Forest River salem Travel Trailor 27RBLE
BuckyBadger is offline   Reply With Quote
Old 11-08-2007, 02:29 PM   #9 (permalink)
Quartz's Avatar
This is exactly where I put mine.
Old 11-08-2007, 03:36 PM   #10 (permalink)
SirKeats's Avatar
ditto. same location here.
i was worried about the angle at first there. the instructions say not to exceed 70 degrees at any given time. the angle in this location is roughly 50 degrees (assuming i measured the angle correctly). so i went ahead and mounted it there.
i suppose this means if you were to travel someplace (downhill) that placed the unit at 70+ degrees, you could run into problems.
Old 11-09-2007, 10:04 AM   #11 (permalink)
mjw357's Avatar
I originally mounted mine right above the parking brake, all the way left. I could see it fine, and could reach it easy with my left hand. Only problem was, it was in the way when using the parking brake. So I moved over to the right, just to the left of the diagnostic plug. I just drilled two small holes in the metal dash bracket and mounted with 2 screws, it is almost perfectly level. Not in the way of my right leg at all. I can still reach it just fine.
Hellz yeah!
Old 11-21-2007, 04:07 PM   #12 (permalink)
blackberry farm's Avatar
Any info on Tekonsha PRIMUS connections? Controller has 4 wires (+,-, stoplight, trailer connector) Factory Titan pigtail has 5 wires (brake signal, ground, Break out, ILL, Fused B+)
Not sure what to do w/ the Break out, ILL ??
blackberry farm is offline   Reply With Quote
Old 11-21-2007, 04:29 PM   #13 (permalink)
Derwud's Avatar
I don't mean to be an A$$hat, but you might want to re-read the posts in this thread, I posted all the wiring info you should need..
Old 11-21-2007, 05:00 PM   #14 (permalink)
Derwud's Avatar
If you go to the 3rd post in this thread and click on wiring help, it should give you all the info you need.
Old 11-21-2007, 05:03 PM   #15 (permalink)
Found it, Thx! Guess I don't need the Illum. Notice you have bags, does it really help the rear sag when towing? What brand did you get?
FS: Tekonsha Prodigy Brake Controller Vegas04 Buy/Sell 3 07-26-2006 02:04 PM
Prodigy Brake Controller bclmread Titan Parts & Accessories 10 07-10-2006 01:13 PM
Prodigy brake controller question... HudsonValleyTitan Titan General Discussion 4 05-17-2006 02:16 PM
Who has best price on Tekonsha Prodigy Trailer Brake controller? ptgarcia Titan General Discussion 3 04-14-2005 05:18 PM
Prodigy brake controller help. Skipete Titan Towing & Hauling 10 05-03-2004 12:32 PM
