Old 04-07-2008, 04:29 PM   #1 (permalink)
Question Transmission temp red-line??
Just got back from towing about 100 miles. I'm using a 2006 Nissan Titan with tow package (9500# tow capacity) to tow a 5000# JayFeather. The truck only has 26000 miles on it and I *was* using TOW MODE. I noticed that whenever I tow on even the slightest incline, the transmission temp goes to nearly red-line and hovers there, then quickly drops back to normal for a few moments. This cycle repeated itself the entire trip. Should I be taking the thing back to the Nissan dealer for a problem?
Thanks!!
Choxnpinz is offline   Reply With Quote
Old 04-07-2008, 04:33 PM   #2 (permalink)
baseballfanz's Avatar
Re: Transmission temp red-line??
are you towing in 4 or "D"? You should tow in 4
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 04-07-2008, 04:47 PM   #3 (permalink)
wanatitan's Avatar
I don't have an answer to your question, sorry. What I don't understand is, If you put your truck in "TOW MODE". Why do you have to keep the truck in 4 instead of drive??? Is that not what the tow mode is for?? Sorry if I hyjacked your thread. I think it pertains though.
wanatitan is offline   Reply With Quote
Old 04-07-2008, 04:49 PM   #4 (permalink)
Darkblueta's Avatar
Send a message via AIM to Darkblueta
Tow mode only holds the first 3 gears longer for towing extra weight. It does not keep the transmission from going into overdrive.
Darkblueta
1998 Trans Am.
Engine, Turbo, intercooled, alky-water injection, 12 bolt, suspension, self tuned and a hell'va lot of fun.
2007 Nissan Titan XE
Daily driver. Beta Testing for Hypertech
Darkblueta is offline   Reply With Quote
Old 04-07-2008, 04:55 PM   #5 (permalink)
wanatitan's Avatar
Got ya thanks!!!!!!!!!! Now back to the problem at hand.
Old 04-07-2008, 04:55 PM   #6 (permalink)
Unfortunately, I was towing in D. I think that may be the problem, but I also think I'm going to take it in and have the fluid & filter replaced since I am worried that I might have cooked the fluid.
I just found it odd that I towed the camper all last summer with no problems and suddenly on this trip the spiking occurred. Didn't even happen on the way TO the campground, only on the trip home, that's why I figured something might be wrong. Thanks for the replies, folks!!
Old 04-07-2008, 07:15 PM   #7 (permalink)
I pull a boat that weighs in at 6,000lbs with my 05 armada with the big tow and just left it in drive. Summer temps over 100 and big hills to boot. I did not notice the trans gauge moving. Maybe your gauge is bad, or maybe your to soft on the pedal and it does not downshift? I think these things will unlock the tq converter instead of downshiftng if your real easy on it, and with a lighter load that could happen.
Mrhavasu is offline   Reply With Quote
Old 04-07-2008, 08:05 PM   #8 (permalink)
loufish's Avatar
You couldn't feel or hear the trans downshifting, or the converter locking, then unlocking?
At 5000 lbs, it takes a pretty flat road with no headwind to keep it in 5th(OD)
I'd be towing in 4th gear all the time...AND downshifting to 3rd on hill before the trans thinks it should.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 04-08-2008, 12:07 PM   #9 (permalink)
desertruner09's Avatar
I agree, don't let the transmission do the shifting while towing at highway speeds. I tow a 3500 lb TT and I tow in D, but I am make sure that the torque converter locks. If it doesn't lock, I pull it down to 4th. Also don't be afraid to grab 3rd and use all the torque that these engines put out in the 3600 to 4000 rpm range, which also helps to cool the trans. fluid. I've had the engine at 3700 rpm up a hill for 15 minutes in 100+ degree weather, zero problems.
desertruner09 is offline   Reply With Quote
Old 05-07-2008, 08:40 PM   #10 (permalink)
Just reading about towing. Do you recommend driving in 4 when towing for the 2008 Titans as well?
blindcoyote is offline   Reply With Quote
Old 05-07-2008, 09:31 PM   #11 (permalink)
loufish's Avatar
For the OP's trailer, yes...For you it depends on what you're towing...Travel trailers, enclosed trailers and toy haulers are like towing a brick into the wind. A small dirt bike trailer with 3 bikes is different.
If you're at 5000 lbs or more, just run in 4th or drop to 3rd as needed...
Born 9/2004
2002 Honda XR650R
Old 05-08-2008, 07:58 AM   #12 (permalink)
HudsonValleyTitan's Avatar
The 4th gear towing thing goes for all Titans. Read the owners manual. I think they say anything over a particular weight...I think it was like 2000 LBS. But you can do the trial and error thing....try it in 5th (on FLAT ground only) and see how it tows and where the tranny temp guage is. If it gets hot or you feel it popping in and out of OD, drop it into 4th. You can also drop it into 3rd on long hills but it's not necessary unless maybe you feel it hunting from 3rd to 4th and back. I tow a good size TT and I keep it in 4th except for long flat areas or long slight downhill jaunts.
- Joe
Transmission Temp question Hayes Titan Engine, Transmission & Drivetrain 2 03-02-2008 07:24 PM
How do You Reduce Transmission Temp.? happenin-dad Titan Engine, Transmission & Drivetrain 27 02-04-2007 02:39 AM
B&M Transmission temp gauge pod.... johnny_munyak Titan Interior Discussion 0 04-12-2006 02:42 PM
Transmission temp sensor blueskys Titan General Discussion 0 06-18-2005 08:07 AM
transmission temp gauge t in ny Titan General Discussion 2 05-29-2005 02:21 PM
