Old 04-08-2008, 09:23 PM   #1 (permalink)
Towing Question
I bought a 06 2x4 SE back in september and it did not come with a trailer hitch, only the bumper hole. I called Nissan today because i am planning on buying a wave runner for the summer and asked how much the wiring would be along with the installation of a hitch. they said it would cost 500 bucks so my question is. should i go to U-Haul and buy there hitch or should i go to nissan and buy the 500.00 hitch?
CoonDogg is offline   Reply With Quote
Old 04-08-2008, 09:28 PM   #2 (permalink)
Nissan Mike's Avatar
Re: Towing Question
Go to a dealer,just not the one that quoted you $500,the wiring is plug n play,the hitch is a bolt on.You could do it yourself with limited mechanical skills.Check around for the best dealer prices,where are you located?
Old 04-08-2008, 09:33 PM   #3 (permalink)
Re: Towing Question
Im located at Chattanooga TN. It is only bolt on? no welding to the frame or anything? I hope you dont think i mean the hitch with the ball that a trailer connects to. i mean the part that goes under the car, onto the the frame that the hitch goes into.
Old 04-08-2008, 09:36 PM   #4 (permalink)
Re: Towing Question
Seriously do some searching on here I want to say the guys are paying around $200 for the OEM hitch kit at the dealer and installing their own.
Make sure the kit has all the relays you need,these may be additional.
I would guess paying about .5 to 1.0 hrs labor would be fair on top of the parts price.
$500 just seems a little too high,take this price quote(below) in and talk with the Svc Mgr(not the advisor) see if he will work on the price with you!
Note:the link below shows a complete kit with relays and the 7 pin connector,also in the link are the install instructions,look it over and decide if you want to do this or pay them to install for you.
Good luck and enjoy your new ride!
http://www.courtesyparts.com/Merchan...de=999T5-A6000
Old 04-08-2008, 10:01 PM   #5 (permalink)
Re: Towing Question
thanks for all your help.
Old 04-09-2008, 05:22 PM   #6 (permalink)
Re: Towing Question
JC Whitney has class 3 hitches for $130. (Curt round tube)
I just bought a draw-tite class 4 for $169. (round tube)
Hitches are bolt on fit for vehicle.
Walmart carries the plug in for the lights with a 7 round/4 flat connector for around $30 (Hoppy 41155)
The (2) relays (lights) are $28 bucks each (dealer) You won't need the brake control relay...yet.
30 minutes installed by myself.
Free_of_the_Big3 is offline   Reply With Quote
Old 04-09-2008, 05:34 PM   #7 (permalink)
slwilson6's Avatar
Re: Towing Question
i got a class 3 with the plug and play 7 round/4 flat wiring harness for $159 for both at uhaul and installed it myself in 30 minutes.
slwilson6 is offline   Reply With Quote
Old 04-09-2008, 08:03 PM   #8 (permalink)
Re: Towing Question
Get Nissan OEM hitch, they look the best by far and they are probably the best for the Titan. Well worth the extra $70 bucks over a non OEM.
2007 Smoke LE
Crew Cab
4X4 Off Road
2007 TITAN LE is offline   Reply With Quote
Old 04-09-2008, 08:04 PM   #9 (permalink)
loufish's Avatar
Re: Towing Question
Don't goof around, get the factory hitch kit...it even comes with the correct bolts. You can search around for best price...
The factory hitch is a Class IV rated, not the Class III offered by others..
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Question about towing. SKEET Titan General Discussion 15 03-11-2007 08:26 PM
towing question dwbse04 Titan Towing & Hauling 10 11-13-2005 05:43 PM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 01:03 PM
towing question gtbigup01 Titan Towing & Hauling 17 10-20-2004 06:28 PM
Towing question bwalkertitan Titan Towing & Hauling 10 04-23-2004 03:45 PM
