Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Drop Hitch - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 04-11-2008, 06:44 PM   #1
tbritt
Question Drop Hitch
Hello all, I have pulled my 21 ft. t/t a couple of times and all seems well but a fellow camper told me I needed a lower drop on the "shank" I went from a 4x2 to a 4x4 and the height is different but I lowered my hitch by the last 2 holes and it seems to set and pull level but when I connect or dis-connect the trailer, the trailer is really high and the fellow camper said thats because I don't have the right drop.....??? What do you guys have on your 07 SE 4x4..thanks tbritt
tbritt is offline   Reply With Quote
Old 04-11-2008, 06:49 PM   #2
Carbeaux
Carbeaux's Avatar
Re: Drop Hitch
I'm confused. Are the truck and trailer BOTH level when you're hooked up? If so, why would you need to change that?
Hook 'Em Horns!
- Frank Zappa
Old 04-11-2008, 07:05 PM   #3
tbritt
Re: Drop Hitch
not really...I have a Draw-tite hitch with equalizer and you have to jack the trailer up to put the bars and chains on, then lower it and set the chains....all is ok there but I have to really get the trailer up high to dis-connent,and thats whats in question ,the friend said if I had a lower drop I would not have to jack it up so far..........??
Old 04-11-2008, 07:27 PM   #4
desertruner09
desertruner09's Avatar
Re: Drop Hitch
I would think having the trailer sitting level while towing is much more important than not having to jack up the trailer as much to connect/disconnect... just my opinion though
desertruner09 is offline   Reply With Quote
Old 04-11-2008, 08:08 PM   #5
HudsonValleyTitan
HudsonValleyTitan's Avatar
Re: Drop Hitch
The trailer being level while in tow is the important thing. To make it easier to hook up and disconnect...especially if switched to a higher riding truck, you can lower the drop a bit. but not too much..you need to keep the trailer as level as possible.
- Joe
NEW - 2008 Blizzard Titan CC PRO-4X OFF ROAD LWB w/TOW, UB & RF pkgs w/XM & Bluetooth handsfree phone system, Nissan bug deflector, Under seat storage box, Nissan factory step rails, LED taillights, Line Of Fire LED Light Bar, Chrome Door Handles, TomTom GO 700 GPS, Extang Tuff Tonno.
Old 04-11-2008, 08:18 PM   #6
tbritt
Re: Drop Hitch
I do thnk I'm ok with what you guys have said and how I feel about the pull, maybe it's because my friend has a electric lift and he see's the 60+ sweat out of me...............maybe I just need the electric stuff...???
Old 04-11-2008, 09:55 PM   #7
gksmith
Re: Drop Hitch
Uh, I just put a block of wood under the jack foot and use it to help raise the trailer.
I swapped my jack wheel to a flat foot that I use 90% of the time. The flat foot doesn't impact things near as much as the wheel did (I had a different tow vehicle at the time).
My trailer is to heavy to try and push around on anything other than level ground - which we don't have at our state parks. The flat foot just works better and the wood helps me level plus allows me to raise the tounge higher without having to crank the jack so much.
Also, I replaced the jack handle with a socket so that I can attach a drill and raise and lower that way - total cost was $6.95 for the socket + drill bit adapater. I already had the drill (450lbs of torque).
2008 4X4 Se CC LWB "Timberline", Popular Package with Captain Chairs, Big Tow, 1Start remote starter, 2* Timing Advance, Westin Sure-Grip Side Steps, Active Tuning, Bed Extender, M&D Dvd & Monitor, Oem Hood Protector, OEM Bed Extender, Vent Visors, HotShot Wiper Fluid Heater, HID conversion, Line of Fire LED bar, OEM Nav Bezel, Garmin Street Pilot 7500, and Boyo VTL350 Backup Camera, Leer 100R Truck Cap, RoadMaster Active Suspension, and 2 Nissan Titan Hats
To be Installed: *Nothing*
gksmith is offline   Reply With Quote
Old 04-11-2008, 10:07 PM   #8
Nissan Mike
Nissan Mike's Avatar
Re: Drop Hitch
These are either inch pounds(equals 37.5 ft lbs),or this is the baddest a$$ drill in the world.
User Name
Password
What hitch drop are you using to tow? cwhyte Titan Towing & Hauling 32 05-03-2006 12:53 PM
Towing Question/drop hitch hughster Titan Towing & Hauling 2 05-05-2005 09:38 AM
Hey SupraTitan - How much drop in your Hitch? Robsc613 Titan General Discussion 0 11-24-2004 11:42 AM
4X4 drop hitch "drop" length???? Icemanrulz Titan Towing & Hauling 9 11-06-2004 12:34 PM
Tow Hitch drop: how much drop do you need on a Titan? Titanoholic Titan Towing & Hauling 13 08-24-2004 09:32 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
