Old 05-10-2008, 04:58 PM   #1 (permalink)
how to control surge brake?
New to the forum..
I have a 04 nissan titan LE crew cab, it has its towing package, my boat trailer has a surge brake, but everytime im backing-up the brakes on my trailer keeps on engaging. what should i do?
jsnd1r is offline   Reply With Quote
Old 05-10-2008, 08:26 PM   #2 (permalink)
Re: how to control surge brake?
Buddy had a boat with surge brakes and same problem. An extra wire from the backup lights needs to be connected to the trailer with the surge brakes that effectively shut the surge off when in reverse. I'm sure it must be on-line discussing the actual fix.
Good luck.
____________________
2007 4x4 SE KC Big Tow DOB 9/26/06
Go Rhino Dominator II step bars
Sirius Radio
Rhino Bed Liner
Keyless Door entry
PRG Leveling Kit
Amsoil Air Filter
Billet Grill
Bgrissom is offline   Reply With Quote
Old 05-11-2008, 03:25 AM   #3 (permalink)
loufish's Avatar
Some surge brakes have a manual valve you shut off before trying to back up, locking out brake pressure to the trailers wheels...incovient to say the least...
Others have(or you install) a "line lock" run by 12 volts that does the same thing electrically, again as posted above actuated by a reverse light wire in the trailer harness.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 05-13-2008, 06:28 AM   #4 (permalink)
I was working with a Load Rite trailer one time and there was a small pin that was inserted into the tongue of the trailer to keep the brakes from engaging.
bfrank is offline   Reply With Quote
Old 05-13-2008, 10:39 AM   #5 (permalink)
FLA-Titan's Avatar
On my 25 Walkaround I have surge brakes. Do you have a 5 pin connector on your trailer? The 5th wire is for reverse and it should activate a solenoid that prevents your surge brakes from locking. If it does have the solenoid, i would check to see if it is working properly. They do go out from time to time. If not, there should be a pin that you can insert into a hole to disable the surge brakes in reverse.
Made by NISSAN, Built by Americans on May 4, 2004!
Mods:
Detroit Locker Tru-Trac
FLA-Titan is offline   Reply With Quote
connecting brake control DrPlay Titan Towing & Hauling 1 02-28-2008 06:54 AM
2007 XE Brake control wiring harness djmiranda1 Titan Towing & Hauling 5 01-02-2007 05:29 PM
Cruise Control & Brake Dust ??s mrclueless Titan General Discussion 8 12-21-2004 06:33 AM
Brake control for towing teeforb Titan General Discussion 5 09-30-2004 06:17 PM
electronic brake control earlofcrankcase Titan Wheels, Tires & Brakes 1 06-28-2004 09:52 PM
