Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
air bags - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 04-21-2008, 05:38 PM   #1
amerrill130
amerrill130's Avatar
air bags
Hey guys need a little advice, want to buy a set of air bags for the titan, but i am not sure if you can put them on a lifted truck? Can you? If you can are they that hard to put on yourself or should i pay someone? Thanks.
amerrill130 is offline   Reply With Quote
Old 04-22-2008, 06:49 AM   #2
GGattorr
GGattorr's Avatar
Re: air bags
I don't have a lifted Titan, but i believe i have read some post that you can depending on the amount of lift.
I just installed the Firestone ride rite kit with Level II onboard compressor. It was a snap. About 1 1/2 hrs to install the bags and about 3 hours for the compressor, but that is only cause I mounted my gauge and control in my dash and that took a little time to make it look better than factory. I have a post with pics that I put up less than a week ago.
Good Luck.
2004 Titan 4X2 SE w/o BT Deep Water POP Pkg
20" Halo Wheels w/305/50R20 8ply A/T Tires, K&N CAI, Flowmaster True Dual 3" Exhaust, Front End Leveling Kit, Class IV Hitch, Chrome Bug Shield, In Channel Ventvisors, Tinted Windows, ARE Tonneau Cover, Chrome Taillight Covers, Chrome Tailgate Handle Cover, Slash Guards, Bedliner w/ Bed Extender, PML Diff Cover, and Ride Rite Air Bags w/Level Commnd II Air Compressor, Prodigy Brake Controller, and Equal-I-Zer Hitch
SEMPER FI
GGattorr is offline   Reply With Quote
Old 04-23-2008, 04:57 PM   #3
yamaguy88
Re: air bags
soo when u put the bags on does it make the back of the truck sit higher when the bags have no air in them? i put a leveling kit on my truck and was looking to put the firestone bags on but woesnt sure if it made the back half of the truck higher or not. kinda want it to sit level. thanks for the input, not tryin to steal ur thread, just didnt want to start a new one.
yamaguy88 is offline   Reply With Quote
Old 04-23-2008, 05:48 PM   #4
helomech
helomech's Avatar
Re: air bags
Your not supposed to have less than 5, or 10 psi in them. I don't remember which, i usually run around 10. I have a level kit, and my truck sits pretty level. No one has ever noticed the bags, everyone thinks my truck sits level.
Old 04-23-2008, 05:51 PM   #5
yamaguy88
Re: air bags
Sweet, thats what i wanted to hear
Old 04-23-2008, 05:52 PM   #6
Jerrygfd
Jerrygfd's Avatar
Re: air bags
I installed the Firestone Air Bags and pretty happy overall. The installation was simple and smooth although the U-Bolt brackets are really too long. I had to cut one end on the passenger side when I installed my Icon rear shock because the bottom bolt wouldn't clear the bracket. Greg had recommended Icon replacement shocks and Air Bags for my particular needs. I didn't use any air controller and just drilled two holes in my trailer hitch receptable bracket for the two air valves. I use a small air compressor to inflate the valves. I first leveled my truck with the air bags when towing to around 25psi for a level look but found there was a little too much Sway at that pressure. I now run 15psi when towing my trailer. I sit at 39" front height and 38.5 rear for towing and keep between 5psi minimum to 10psi with my vehicle heights even at 39" when not towing. I'm looking at OEM SAW replacement for the front right now.
2004 Smoke Color SE 4 X 4 Crewcab fully loaded with Off Road Package, Popular Pkg, Util Pkg, Big Tow Pkg, SplashGuards, Floor Mats,
I installed after purchase: *Dealer installation
Bug Deflector,
Wade Window Vent Visors
Westin Platinum Step Rails
Carriage Bolt Billet Grilles Upper and Lower
Stillen Dual Rear Straight Exhaust Part #509547*
K&N 77 Series Polished Alum Air Mod Kit #6012KP*
Trailmaster Front Coil Spring Leveling Kit #NL220*
Husky rear floor mats
TruxedoTonneau Lo Pro Cover
IPOD Interface Kit
Firestone Ride Rite Air Bags part #2355
Towing on vacations: 2008 Keystone Hideout 28'
Model 27B Travel Trailer with Eaz-Lift 1000/14000 WD and Robins Sway Bar.
DR Rear shocks
Future Mods: Front SAWs coilovers or Bilstein Adjustables
Jerrygfd is offline   Reply With Quote
Old 04-23-2008, 11:14 PM   #7
Stardumb
Re: air bags
I keep mine at around 15-20 psi. They are Firestone but not sure which ones. I have a 12in bulletproof kit with King Shocks and Atlas Leaf Springs in the back, the front stands a little higher than the back, kind of a prerunner look.
Stardumb is offline   Reply With Quote
Old 04-27-2008, 06:11 PM   #8
ptvolly
ptvolly's Avatar
Re: air bags
I've got Air-Lift on mine, with 6" of lift. Works great, pretty easy to install (although you do have to drill your frame).
If you pump the bags up with no load, it will raise the back, but it's also a very harsh ride, so certainly not worth the "look".
'05 Smoke CC LE 4X4
PC 6" Stage 1
PC 6059 18x9.5
PC Xtreme A/T 325/65/18
Magnaflow "cat-back" / Tint / NISMO CAI / 6k HID / Westin Bull w/ PIAA lights / Truxedo / Carriage Works Grill / Smoke LED tail lights
ptvolly is offline   Reply With Quote
Old 05-11-2008, 12:39 PM   #9
pyromedic
pyromedic's Avatar
Re: air bags
I have the 4x2 LE CC so the truck now sits a little high in the back. What is the best way to level the truck and still have the ability to tow a 8,000lb trailer? I want to add the air bags and maybe lift the front to level it out but, I've heard stories about a lot of squeeks and rattles from messing with the frontend.
LE CC Titan / Silver 05'
Big Tow/Navi
Born on 10-09-04
number 1301
pyromedic is offline   Reply With Quote
User Name
Password
AIR SHOCKS or AIR BAGS??? Need Help! SweetRide#111 Titan Suspension 4 01-22-2008 09:30 AM
Where did you get your Firestone air bags? BuckyBadger Titan Towing & Hauling 9 07-03-2007 12:33 PM
Bags Or Lift? comeonitsatitan Titan Suspension 11 06-23-2007 11:59 PM
air lift bags AETitan Titan Suspension 5 05-30-2007 10:29 AM
side air bags? texag Titan General Discussion 1 03-11-2004 10:43 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
