Old 04-22-2008, 08:13 PM   #1 (permalink)
towing with a lift
will towing with a lift decrease the amount i can tow with the vehicle i do have the big tow package
wl07 is offline   Reply With Quote
Old 04-23-2008, 08:39 AM   #2 (permalink)
Re: towing with a lift
If your truck sits level without a load, yes.
If you're not re-geared to accomodate the tires (35" or larger), yes again.
'08 Titan SE, Crew Cab, 4wd, LWB, Smoke
Bullwinkle is offline   Reply With Quote
Old 04-23-2008, 10:39 AM   #3 (permalink)
so if i put jus the leveling kit on the front it will decrease my towing weight, or will i still be fine.
Old 04-23-2008, 10:56 AM   #4 (permalink)
Megw3788's Avatar
Send a message via AIM to Megw3788
With just a leveling kit you'll be fine. The actual lift kits don't really effect anything other than making your truck sag in the rear when it's loaded because they level the truck out so when it's loaded the rear sags instead of being level like a loaded stock truck. It's the bigger tires that effect the towing capacity more than the actual lift. But if you don't want your truck to sag in the rear when it's loaded you can buy air bags, or do the PRG mini lift so it's taller, yet it keeps the factory forward rake.
Megw3788 is offline   Reply With Quote
lift kit and yaw while towing catchandkill Titan Suspension 11 01-26-2007 10:47 AM
towing with PRG lift ~~~~ pyromedic Titan Towing & Hauling 5 01-25-2007 12:46 PM
Towing with a lift? Mikehos Titan Towing & Hauling 3 10-09-2006 05:57 PM
Which lift is best for towing? Mikehos Titan Suspension 4 10-06-2006 01:09 PM
6" Lift - What happens to Towing?? SoulFish Titan Suspension 3 06-08-2005 07:08 PM
