Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
extra bracket on 08 when installing hitch - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 02-02-2008, 10:58 AM   #1
blizzardtitan
Took off my 05 hitch and went to install it on the 08, but there was already a bracket mounted in that location. The bracket is identical to the mount on the hitch but it also has another bracket attached to the inner part of it with two more bolts for a total of 5 per side. I removed it and used the bolts that were on it to attach my 05 hitch, the bolts looked the same just newer. My question is has anyone bought a 08 hitch and does it have the extra 2 bolts per side. Or has anyone with 08 bt looked under theirs to see if it's like this. I'm not sure why the factory put those brackets on, since that is like 1/2 of the hitch. Also anyone no where I can get the blue relay online for cheaper than $27? Thanks
New: 2008.0 Titan CC SE 4x2 Radiant Silver
Old: 2005 Titan KC SE 4x2 Blizzard
2007 Suzuki ltr-450
blizzardtitan is offline   Reply With Quote
Old 02-02-2008, 12:43 PM   #2
TitanTeamRoper
TitanTeamRoper's Avatar
Re: extra bracket on 08 when installing hitch
I remember reading on here that the brackets were probably put on there for shipping, at least that was the conclusion everyone cam to.
2006 LE 4X4 Crew Cab Galaxy Black
Big Tow, OFF-Road, Nav, Sunroof
Current mods
2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
TitanTeamRoper is offline   Reply With Quote
Old 03-31-2008, 07:35 AM   #3
nissan72
i ran into the same problem...i guess i'll just take of the brackets...they look like tie downs from the factory.
nissan72 is offline   Reply With Quote
Old 03-31-2008, 07:44 AM   #4
Derwud
Derwud's Avatar
Remove the brackets and install the hitch... They are factory tie downs and unless you plan on shipping your truck somewhere.
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 03-31-2008, 02:46 PM   #5
nissan72
I got it...found another thread with more answers.....hitch installed.
Old 05-13-2008, 05:03 PM   #6
plunge
So remove the bracket and install the hitch thats what it looks like to me.Or is there more to it ,this ones new to me I insatalled the rest but I don' remember the bracket.Never mind figured out on my own.............
plunge is offline   Reply With Quote
User Name
Password
Where to get recovery strap and Receiver Hitch D-Ring Bracket? gksmith Titan Towing & Hauling 6 02-24-2008 02:00 PM
How Much - Extra Key SirKeats Titan Parts & Accessories 4 09-23-2007 10:45 AM
Difference between pc carrier bearing drop bracket and CST bracket pi3yeargrad Titan Suspension 6 09-23-2006 08:47 PM
installing hitch? topherdbu Titan Towing & Hauling 16 09-11-2006 05:37 PM
Installing Hitch and Wiring Trailer Brake Light Plug pilot4net Titan Towing & Hauling 9 10-27-2004 04:52 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
