Old 04-24-2007, 06:27 AM   #1 (permalink)
Dirt in the tailgate
Over the weekend I was hauling some topsoil and noticed when I was unloading small pieces of dirt would roll off the top of the tailgate and into the area where the tailgate latches to the truck. There is a hole that all this dirt was going right into the tailgate. So how can I get this dirt out? Can I remove the plastic cover and get access to the insides of the tailgate enough to get a shop vac in there?
On a side note..... DO NOT EVER USE A LOADHANDLER. I used one to help unload the dirt mentioned above and for one, I had to manually unload half the dirt with a shovel before I could even get the dirt to move with the loadhandler. Then after I'm done, I remove the loadhandler from my tailgate only to find that it scratched the sh!t out of my paint! Putting in a backyard is really costing me some $$$$$.
'04 SE KC 4X4
Galaxy Black
Big Tow
Popular Package
Mods:
Tech Tubes step rails, Truxedo Lo-Profile, K&N CAI, Flowmaster catback exhaust
MB Motoring Express 20"X9", Nitto Terra Grapplers 305/50 - 20
Sylvania Silverstar hi & lows, OEM fog lights, Blacked out OEM Grill
Armada front air dam, 2* timing advance
meckman is offline   Reply With Quote
Old 04-24-2007, 08:08 AM   #2 (permalink)
Re: Dirt in the tailgate
I remembered that power tailgate thread from pciley had some good pics of the tailgate. Looks like I will be able to remove the plastic and get a shop vac hose in there.
One cool thing about the hole experience was seeing the Titan haul 2 yards of topsoil. She was squating pretty good, but I never felt it hit the bump stops.
Yikes, just did a google search and saw that 1 yard or dirt can be somewhere between 900 - 1,800 lbs (depending on moisture content), and I had 2. Just a little over the 1,500 lb bed rating. ooops.
'04 SE KC 4X4
Galaxy Black
Big Tow
Popular Package
Mods:
Old 04-24-2007, 08:11 AM   #3 (permalink)
gadget74's Avatar
Can you not just run some water through it?
If dirt can get in there then water can too...........
Confucious say - Crowded elevator smell different to midget.
GoGoWhoreŠ
Helo Black Maxx 17's, BF Goodrich AT's, Jensen 7" indash DVD, 8" flip down monitor., 10" sub., Airbox Mod w/K&N Airfilter, NCD 2" Level Kit, Painted black rear bumper, Black Powder Coated Perforated Alum Grill, Magnaflow, Memphis door speakers, 2 degree timing advance!
gadget74 is offline   Reply With Quote
Old 04-24-2007, 08:14 AM   #4 (permalink)
I thought about that, but I don't think the weep holes at the bottom of the tailgate are large enough to get all that dirt out.
'04 SE KC 4X4
Galaxy Black
Big Tow
Popular Package
Mods:
Old 04-24-2007, 08:19 AM   #5 (permalink)
Fox Delta's Avatar
if you are talking about the holes in the bottom of the tailgate those are actually the "drains" -- I 4wheel in the mud and just stick the water hose in the hole in the side there until the water runs clear out of the drain - I do have to go from one side to the other the make sure it's all out.
Yeah that would be a bit over the load rating reminds me of the time I put 300 sq ft of ceramic floor tile in my F250! whoops
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
33x12.50/17 Mickey Thompson MTZon Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
Old 04-24-2007, 08:27 AM   #6 (permalink)
gadget74's Avatar
I haven't looked at them, but it was just a thought.
Good luck and let us know your results.
GoGoWhoreŠ
Old 04-24-2007, 08:32 AM   #7 (permalink)
Fox Delta's Avatar
hmmm - seems like if your tailgate was open then that's where the dirt would have entered?? or did it go in thru the big holes on the side??
2004 XE 4x4 CC OR
Old 04-26-2007, 08:44 AM   #8 (permalink)
QWIKWHIP's Avatar
Do you mean 3000? Cuz I've had over 300 sq plus 4 80lb bags of mortar in my Titan with no problems. I've had 3 yards of mulch in my truck as well. That was a load! I think the yard guy wanted to see how high he could pile it! lol
Old 04-30-2007, 12:01 AM   #9 (permalink)
Fox Delta's Avatar
I thought he said it was 300 - a guy drove it in on a pallet with a forklift - the back of that Ford P.O.S. just kept saggin'. those were the big 16x16 tiles each one was like 10lbs
3 yards of mulch? yeah that's a load!!
2004 XE 4x4 CC OR
Old 05-16-2007, 07:58 AM   #10 (permalink)
I took the tailgate off and washed it all out. The only issue is I wasn't too careful with removing the platic cap on the top of the tailgate and broke off some of the tabs. It went back on OK, but it's a little loose now. Might call up the dealer to get a price on a new plastic top piece. Probably 100 bucks or so..... Other than that, the removal was easy and I got all the dirt out. Had some dirt in the hinges too that I could hear grinding a little when I would close the gate. So got all that out too.
'04 SE KC 4X4
Galaxy Black
Big Tow
Popular Package
Mods:
Old 05-16-2007, 12:02 PM   #11 (permalink)
Quick update. Just ordered up a new plastic top piece for $32.00 shipped off of Courtesy. Not near as bad as I originally thought.
'04 SE KC 4X4
Galaxy Black
Big Tow
Popular Package
Mods:
Old 05-16-2007, 01:12 PM   #12 (permalink)
killcatzforfun's Avatar
[quote=Fox Delta]I thought he said it was 300 - a guy drove it in on a pallet with a forklift - the back of that Ford P.O.S. just kept saggin'. those were the big 16x16 tiles each one was like 10lbs
i had 320sq ft of tile in mine last week with no sag at all.. i also had 2 50lb bags and 2 35 lb bags of mix in there with my saw and other stuff i bought to...
killcatzforfun is offline   Reply With Quote
Old 05-21-2007, 12:43 AM   #13 (permalink)
Fox Delta's Avatar
[quote=killcatzforfun]
yep that's a good bit !! I am so glad to be rid of that Ford -- whew!!
2004 XE 4x4 CC OR
Old 05-30-2007, 09:23 PM   #14 (permalink)
catitanfan's Avatar
I'm Affraid I am going to have this happen when I put my Quad in the back after duck hunting this season. I hope not!
catitanfan is offline   Reply With Quote
Old 06-04-2008, 04:35 AM   #15 (permalink)
I know this is an old thread, but I had the same problem this weekend when I was moving mulch. I had take then piece of the plastic off the tailgate (it's the vertical, when the gate is closed, inside piece that covers the tailgate) but I couldn't get to the inside. I didn't take off the top plastic piece and it looked like there was a "metal" flap on the expose face of the tailgate, but I didn't want to bend it.
How do I get in to clean it out - I'm worried about the mulch holding water in there and causing rust.
Any pics will help!
Thanks,
George
gchu is offline   Reply With Quote
ABS sucks on the dirt... workman1000 Titan Wheels, Tires & Brakes 20 11-05-2006 11:15 AM
YES:1 ATV & 1 Dirt bike will fit in a CC MOTO-MAX-TITAN Titan General Discussion 9 08-01-2005 01:06 PM
Who needs a dirt bike? MOTO-MAX-TITAN Buy/Sell 60 06-02-2005 10:49 PM
Got a wee bit o' dirt on her! xsive11 Titan Pictures & Media Post 23 04-27-2005 03:52 AM
Dirt Bikers Howzit Titan General Discussion 19 07-13-2004 06:28 PM
