Adding a tow package to a titan - Nissan Titan Forum
post #1 of 21 (permalink) Old 06-04-2008, 07:43 PM Thread Starter
iTrader Score: 0 reviews
I am looking at an 06 titan that does not have a towing package. Is the factory tow package a different setup then an after market one? Do all titan's have a tranny cooler and will they all pull 9100lbs?
smitty707 is offline
Advertisement
post #2 of 21 (permalink) Old 06-04-2008, 08:20 PM
HudsonValleyTitan's Avatar
Re: Adding a tow package to a titan
Only tow equipped Titans tow that much and yes...all Titans have the tranny cooler. Non tow equipped trucks only tow up to 7400 LBS. The difference is the gearing...although if you have the OR package, you have the lower gearing and can tow the higher weight.
HudsonValleyTitan is offline
post #3 of 21 (permalink) Old 06-04-2008, 08:23 PM
sligsta's Avatar
Non BT Titans are rated for 7500lbs. The biggest thing to get the 9100lbs is the diff gears. Other than that the BT pkg. gives you the hitch, BT mirrors, and a tranny temp gauge. So basically if you want to tow that much you would need to do a gear swap and I would reccomend swapping to LT tires. As far as I know that's it but I could be missing something. As far as I know all Titans have a trans oil cooler. You can always get a Scan Gauge to get a trans temp gauge.
08 SE KC 4X4 SMOKE
sligsta is offline
post #4 of 21 (permalink) Old 06-04-2008, 08:24 PM
sligsta's Avatar
HVT beat me to the punch
08 SE KC 4X4 SMOKE
sligsta is offline
post #5 of 21 (permalink) Old 06-04-2008, 10:28 PM
loufish's Avatar
iTrader Score: 11 reviews
If you decide to upgrade your Titan to tow at all, get the factory hitch kit...it comes with all the relays needed to run the trailer lights, the factory hitch is great, even comes with the factory bolts to attach the hitch...
I believe the is a 7 pin harness back-taped to the rear bed wiring harness to access for the trailer wiring...The hitch kit may come with instructions for that...
PRG Performance Kit w/SAW's
Rear Bumpy-Bumps
35" General Red Letter Grabbers on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
loufish is offline
post #6 of 21 (permalink) Old 06-13-2008, 07:15 AM
what loufish said. i went third party on an aftermarket hitch setup, and while i really like the way it looks (pretty much all of it is hidden underneath the rear bumper) it has been a pain trying to figure out a decent way to mount the trailer light connector that i bought (it came with the appropriate relays)...so for now i only plug in the harness whenever i need to tow something. the rest of the time it dangles.
wish i would have bought the OEM hitch kit.
asher is offline
post #7 of 21 (permalink) Old 06-13-2008, 07:19 AM
54warrior's Avatar
iTrader Score: 2 reviews
They (Nissan) should have incorporated the 7-pin harness into the bumper itself, where it's out of the way and not hanging off the side of the hitch like a big wart, just asking to be yanked off somehow.
Truck: 05 CC SE 4x4
Performance/Drivetrain: JBA CAtback w/ 2* Advance, PRG Driveshaft Spacer, PRG Street Traction Bars
Suspension: PC 6", SAW Coils, ProComp MX6 Adjustable Rear Shocks, Total Chaos Shackles, removed anti-sway bar
Wheels/Tires: Stock 6 Spoke Charcoal Wheels with Nitto Terra Grappler G2's-325/65R-18
Brakes: Stock w/ PRG Stainless Lines (Front)
Lighting: (3) Hella 500 Driving Lights
Misc: Husky Liners, Bug Shield, Tonneau, Bed Liner'ed Rockers, Home-Made© Skid Plates, Vent Visors
54warrior is offline
post #8 of 21 (permalink) Old 06-13-2008, 08:14 AM
TecheTitan's Avatar
iTrader Score: 1 reviews
I agree with you on that one 54!
06 Smoke SE CC 4X4
Bug Shield, in channel vent visors, 22% front window tint, Pro Comp stage1 w/ SAW coilovers and 2" rear block w/ 35x12.5x18 Toyo Open country MT on 18X9 KMC Monsters, JBA cat-back, 2* advance, AEM intake, BD Power Pup
TecheTitan is offline
post #9 of 21 (permalink) Old 06-13-2008, 04:28 PM
Darkblueta's Avatar
Send a message via AIM to Darkblueta
I do not have big tow, but this is what I ended up doing....
1. Hitch...http://www.etrailer.com/pc-H~70530.h...cleid=20074651
2. Fuses/etc...http://www.etrailer.com/p-30608.htm
3. Ballmounts...picked up at a local store.
4. Transmission gauge...http://www.clubtitan.org/forums/show...nsmission+temp Instructions on where to add and mount the gauge.
I think everyone else already covered the rest. If you want the tow mirrors, one of the nissan parts sites have them. I am thinking of finding a wrecked BT titan for the mirrors. I don't tow anything super heavy(just my car) and don't need the gears(I'm not saying if I found a set at a really good price, I would pick up the gears and a tru-track and install them).
Hope this helps.
Darkblueta
Toy: 2001 Camaro SS m6 free ram air cutout + slp lid
1998 Trans Am turbo, suspension, intercooled/alky-water injection, etc - sold
DD: 02 Stratus or 07 Titan
Darkblueta is offline
post #10 of 21 (permalink) Old 06-13-2008, 07:04 PM
darkblueta,
that's the same harness and fuse set that i bought, but i cannot find a way to mount it to where it looks decent.
did you buy the long no-drill mounting thing that hose clamps onto your hitch?
any pictures of your install would give me some insight.
definately agree with you 54!
asher is offline
post #11 of 21 (permalink) Old 06-13-2008, 08:04 PM
DeadRiver's Avatar
iTrader Score: 4 reviews
Send a message via AIM to DeadRiver
bought the oem hitch for 100 bucks!
towed this:
12k one mile... def wish i had the gears. trailer was cake empty, only 2800.
BT mirrors would have been nice too, all in time as the buy/sell section does it's thing!
2004 Sedona Titan LE CC 4wd
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
PA Chapter Director
Link to MVP Titans Facebook Page
I should stop having my suit dry cleaned, it seems to kill people.
I'm not worried, I have a Titan with 4wd and a pair of balls.
You can lead a moron to knowledge but you cannot make him think.
I should probably buy more bullets.
The darkest hour is before the dawn.
The Urinator™
DeadRiver is offline
post #12 of 21 (permalink) Old 06-13-2008, 08:06 PM
DeadRiver's Avatar
p.s. you'll probably need an adapter before plugging a boat trailer in....
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
PA Chapter Director
The Urinator™
post #13 of 21 (permalink) Old 06-13-2008, 08:16 PM
iTrader Score: 10 reviews
I got the Nissan factory hitch for $190.36 and had the tech put it on for me out back. I also bought the BT mirrors for $180 for the set (shipped). I'll be getting a trans temp gauge of some type here pretty soon, as I am taking my TH to Pismo 7/31 - 8/4. As far as the heavier duty battery, don't need it. I have not yet towed with my Titan but I will post back when I do and let you all know how it does.
2006 Nissan Titan XE C/C - Granite, XE Preferred Pkg, Flowmaster SI/DO Muffler, 2* advance, 2.5" PRG Spacer, Pro-Comp ES9000 rear shocks, chrome door handles.
2008 Carson FL162 Fun Runner Toyhauler
PSNissanFleetMgr is offline
post #14 of 21 (permalink) Old 06-13-2008, 08:23 PM
towed this:
That trailer weighs 2800 LBS? And the boat is 12k LBS? Did you fill them both with lead?
post #15 of 21 (permalink) Old 06-13-2008, 08:43 PM
DeadRiver's Avatar
yes, the trailer is 2800, (per the unlaided weight posted on the trailer registration. not sure the accuracey) the boat is roughtly 9000 + fuel. I'd like to put the set up on a scale just to see. he pulled it out last season with an f350
1986 26' Welcraft, twin 260 merc cruisers (chevy v8's) widest trailerable beam 9' or more maybe. it's when the made boats to last....
better boat pic:
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
PA Chapter Director
The Urinator™
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Adding the Tow Package rgtitan Titan Towing & Hauling 2 07-16-2007 05:28 PM
Adding tow package/5th glory Titan Towing & Hauling 12 07-09-2007 05:26 PM
Adding XM with Nav package truck? tried search Chris_in_the_Mojave Titan General Discussion 2 10-26-2006 02:18 PM
Titan NAV - where is the DVD-ROM if you don't have DVD package? Sc0rp10n Titan General Discussion 12 02-28-2005 11:41 PM
Are Popular Package and Utility Package Worth it? whistler Titan General Discussion 18 11-01-2004 07:07 AM
You may post new threads
You may post replies
