Re: trailer lights
The Trailer running lights relay is powered by fuse #32...I don't know what color it is...Check the fuse...a 10 amp
I think you should have 1 brown relay and 2 blue ones...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
