Cars.com reports a payload of 2063lbs for a 2008 Titan LE Crewcab. My door sticker says 1485. Why the descrepency? What could be done to increase the payload? I am concerned about the hitch weight of my trailer.
08 Pro 4X RED ALERT SWB Crew cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a Clipper 1465HST Trail ready pop up. Grumpy Old Man Club http://s3.bite-fight.us/c.php?uid=214743
pickuptrucks.com
2,062-pounds for Crew Cab and 2,012-pounds for King Cab. Changes were made to the rear axle and suspension to accommodate one ton of cargo. The rear axle has been beefed up with a larger diameter shaft and upgraded leaf spring seats and brackets. Rear leaf spring rates have also been changed to provide better damping. The rear suspension also receives stronger upper and lower shock brackets.
here you go!
2007 Galaxy Black, CC, 4x4, Big Tow, Off Road.
Custom Dual FM 40 Series Exhaust, AEM Brute Force CAI, 2* Timing Advance, 2 JL Audio W3 10" Subs, De-Badged, De-Chromed, Pro- Comp 6" Lift, Radflo Coilovers, 20x10 KMC D-Backs, Nitto Terra Grapplers 305/55/20
What's the GVWR of the truck, also on that sticker?
PRG Performance Kit w/SAW's
Born 9/2004
What year is your truck. My 06 has a 1400 pound payload. I wish I had the payload of the newer trucks.
Essentially Stock 2006 SE 4WD with Bilstein HD's
Security System: Glock
I don't have a payload stated on my door sticker and don't remember seeing one on other trucks, usually you get the trucks GVWR and because the true empty weight can very the payload isn't posted on that sticker...usually
Born 9/2004
I thought that too until I looked a little closer at the Tire Loading/Pressure sticker. For my 06 CC SE 2WD with BT, it says I only have 1213 lbs of cargo capacity... Could it be possible that it is weighed from the factory then printed on the sticker after it is on the truck?
2006 Titan 2wd CC SE Granite w/Big Tow with 80K miles
DIY Airbox mod with drop in AMSOIL Absolute Efficiency Air Filter and a DIY CAI //// Stillen Sport Rotors with Hawk HPS Pads //// Goodridge SS Brakelines //// Active Tuning Grounding Kit //// 265/70 R18 Toyo Open Country H/T Tires //// PRG Shackles //// Hellwig HD Traction Springs //// PML Differential Cover with Mag-Hytec gasket //// Armada Air Dam //// Headlight Mod (black)
Ya, that does not make since as you should have a higher payload.
I can only wonder if your truck was an early one built in 07 that was not up-specced yet. That does not make any since either. IIRC the payload went up to ~ 2000 pounds on the 08 MY.
It's all about your tires. You have to add the back weight of your truck + the amount of weight you want to haul. That's why duallys have 4 rear tires. Not for traction, but for load bearing.
