Old 04-07-2009, 06:09 PM   #1 (permalink)
Trailer lights do not work
I have a 06 Nissan Titan and put on a trailer hitch and bought the 7 pin adpator. Connecting the trailer, trailer lights do not work. The plug is not getting any juice. I've read several posts related to this topic, but can't identify the problem. I checked the fuse box under the hood on the passenger side and there are no fuses at all for the fuse slots that are labeled for trailer lights. Is this were the fuses are located for the trailer lights? I've read in some posts that there is a fuse box located under the dash on the driver side for trailer lights. I can't say that I know much about truck repair.
Thanks for the help.
Also, what fuses should be used - 10, 15, 20?
Thanks again.
augustabuck89 is offline   Reply With Quote
Old 04-07-2009, 06:21 PM   #2 (permalink)
BuckeyeTitan's Avatar
Re: Trailer lights do not work
When I bought my 7 to 6 and 4 pin adapters it switched the wires to the trailer. Mine made the hot wire from the truck go to the trailer brakes so the brakes were locked on and that made it interesting when I started dragging the trailer with the brakes locked up so you may want to check your adapter. I believe the 3 fuses for trailers are under the hood but it should say in the manual. Welcome to TT
IRC VK56 Member
2005 Nissan Titan King Cab Se
Mods: Extang Fulltilt tonneau, AEM Brute Force CAI, Superchips Cortex 87 octane tune, Toyo A/T's, Next generation JBA exhaust
Fastest time ever at a track on ice in a 2wd Titan as far as I know: 60 ft 4.86 1/4 ET 22.17
Times on 5/9/09 - R/T .064, 1/4 14.849, 1/4 mph 91.62
Voted 2009 High School Nationals Best Import Truck
College beater:
2004 Dodge Dakota 4x4 extended cab
Mods: line-x, 10% tint rears 35% tint front, Extang Fulltilt tonneau, Sony head unit, alpine speakers all around, Rancho RSX shocks
Times on 6/3/09 - 1/4 17.275, 1/4 mph 79.29
BuckeyeTitan is offline   Reply With Quote
Old 04-07-2009, 08:28 PM   #3 (permalink)
You need three relays and one fuse. The relays can be purchased at your local dealership for one arm and half a leg.
And somehow the fuse will mysteriously come up missing - or at least mine did the last time I hooked up a trailer. I guess there must be a fuse gremlin out there somewhere because I never found it.
2008 Titan XE (best truck ever so far)
2007 Shelby GT #117
2008 New Holland T1510
1971 FORD TLB
stump_breaker is offline   Reply With Quote
The Following User Says Thank You to stump_breaker For This Useful Post:
plio7 (04-07-2009)
Old 04-07-2009, 08:36 PM   #4 (permalink)
you answered my question thanks alot
plio7 is offline   Reply With Quote
Old 04-08-2009, 05:05 AM   #5 (permalink)
mjw357's Avatar
If you have to buy relays, save yourself some green and buy them from U-Haul, much cheaper.
We need to make a sticky for this wiring crap.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 04-10-2009, 05:21 PM   #6 (permalink)
I know where the 3 relays go. Where will the fuse be used? Thanks.
Old 04-10-2009, 09:02 PM   #7 (permalink)
It will be in the fuse box not the relay box, on the bottom row (toward the front of the truck) if I remember correctly.
2007 Shelby GT #117
1971 FORD TLB
Old 04-11-2009, 09:59 AM   #8 (permalink)
thebassn8tr's Avatar
There are sooooo many threads on this.
thebassn8tr is offline   Reply With Quote
Old 04-11-2009, 11:41 AM   #9 (permalink)
MSrockyblue's Avatar
Send a message via MSN to MSrockyblue
I tried a connecter from Napa and everything worked except the tail lights. I had to tow with it at night and had no problems but I was nervous about police. Is one of the relays or the fuse just for tail lights?
MSrockyblue is offline   Reply With Quote
Running Lights Only - Trailer Brakes, Brake Lights, Signals Don't Work grd264 Titan Towing & Hauling 11 01-09-2009 09:59 PM
Trailer running lights don't work speediq99 Titan General Discussion 4 06-22-2008 03:06 PM
trailer running lights dont work ehill Titan Problems & Dealer Service 6 09-11-2007 08:19 PM
Trailer running lights won't work JWibbs Titan Problems & Dealer Service 3 08-27-2007 10:32 PM
Trailer Lights : running lights not working Chance2336 Titan Towing & Hauling 9 09-12-2006 06:33 PM
