I need a tow hitch and found that the U-hauls are the least expensive- about $140. Anybody running u-haul brand - likes? dislikes? Is there anything out there at a lower price? I'm cheap I know, but I will rarely be using it.
"Gratitude is the open door to abundance" by unknown
Make sure they provide all the necessary relays to run all the trailer lights.
Jim
If it is $140 including the relays it's a great deal. Otherwise, go with a factory hitch that looks better and should come with the relays. I paid $75 for the relays at my local dealer. You may need a wiring harness as well.
A Uhaul hitch should be fine, I just suspect it's $140 for the hitch x$ for a harness plus the relays.
Essentially Stock 2006 SE 4WD with Bilstein HD's
Security System: Glock
i got there tow hitch on mine and I love it. to me it looks better than the stock one. Plus was cheaper than the OEM one. They also have a great warranty as well. They will replace it if it ever gets messed up and the guy was like if someone rear ends you and it bends then they will replace it for free. I was like cool but if someone rear ends me that bad I think Im going to have more on my mind than getting a new hitch put on.lol
__________________ SOCAL VK56 RACING IRC VK56 Member
07CC2WD Performance:2*Advance, S&B w/ Ram Air, Dual Pro Street Spintech exhaust, Relentless catch can, JBA shorties, Magnaflow cats, Uprev Exterior:NCD Leveling, Tinted Tails, Blacked Headlights
Yeah they offer a lifetime warranty on their hitches..at least the one that was put on the Bronco back in 2005. A hitch is a hitch, it's metal and does what it's suppost to. However the UHAUL sticker they slap on there is pretty ugly lol
I have had a U Haul hitch on my Titan since the first week I had it in Aug of 05. I think I paid $109 for the hitch and around $40 for the relays, and $25 for the wiring pigtail from behind bumper to a 7pin RV plug that I mounted in the bumper. At that point the dealer wanted around $300 for the hitch package but it came with everything. I think the U Haul it tighter to the bumper than the Nissan hitch, but the Nissan hitch looks nicer. Tow rating is the same. Nissan hitch has a place to mount the RV plug, A 35" spare will fit on the stock wheel with a U Haul hitch for sure, don't know about the factory hitch.
2005 King Cab 4x4
DR coilovers with PRG spacer
PRG Upper Arms
35" Coopers
I was looking into the same thing. The Nissan bumper on my truck is up to 10,000 pull. I want a class4 hitch at least. I've towed some heavy shiz with just the bumper but now I want a tow packege for the looks. Another guy I know got a class 3 hitch from u haul for around 100. I picked up my wiring harness from Napa for 30. I didn't have tail lights though.
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
Quartz is correct. According to the 2007 Nissan Titan Towing Guide the Titan bumper hitch is a Class III hitch with a maximum trailer weight of 5,000 lbs and a maximum tongue weight of 500 lbs.
Jim
Just don't have them install it. I rented a trailer to someone who just had Uhaul put on a hitch on their Cherokee. Needless to say they lost the trailer 2 miles away because 2 only bolts were installed, also they didnt hook up to brake light circuit, only turns and parking.
2007 Titan XE KC Galaxy Black
Line-X bedliner
Flood lights installed in bed walls
Airraid Intake
Power tailgate lock
6 Head strobe light system
Strobes in headlights, cargo lights, and taillights
Federal Signal headlight flasher
100 Watt Federal Signal SmartSiren
LED bumper warning lights
AVS bugshield
LED grille marker lights
Other rides:
2007 Altima 2.5S 1998 Ford Windstar
1987 Ford Bronco "Big Fugly" 1999 Dutchmen 30FK TT
