What a truck. Just bought a 2008.5 Titan 4x4 KC on Monday. wow. Anyway, I have a 16' Bass Boat that weighs around 1600 lbs. with trailer & motor. Do I need to have electric brake controller installed?
The Following User Says Thank You to Crappie Master For This Useful Post:
Congrats on the new truck. I think if you are properly set up you can do up to about 3500lbs before really needing a brake controller and brakes. Don't quote me on it though.
Maybe true but even with a light trailer brakes are useful for calming down a swaying trailer.
The Following User Says Thank You to typerr For This Useful Post:
You should need a brake controller for a boat and trailer that light, but it doesn't hurt to have one for other possibilities. Typically, if a boat trailer has brakes, it is surge brakes since electric brakes could cause issues if they aren't properly sealed and maintained when putting the trailer in the water. As a general rule, 3500 lbs is the limit for not legally requiring brakes on the trailer, but some state vary. Personally, I prefer not to pull more than 3000 lbs without brakes for the safety factor--never know when some dummy will pull out in front of you and slam on his or her brakes. I had someone do that to me this morning, and I wasn't sure if I'd stop in time since I was pulling my 18' Skeeter to the lake. That trailer doesn't require brakes, but when I need to replace the bearings in the hubs, I my just install a surge brake setup anyway.
'07 Nissan Titan LE CC 4x4 w/ Pro-4X wheels
1985 Skeeter SF-175 w/ 150 HP Evinrude
The Following User Says Thank You to jljue For This Useful Post:
I believe the state regs dictate minimum trailer brake requirement...I think in Kalifornia anything over 2000 lbs you're supposed to have some sort of trailer brakes.
I've towed under 2000 lbs a lot and I'd not worry too much about it, of course do increase your stopping distance, but I recommend that brakes or no brakes...
PRG Performance Kit w/SAW's
Born 9/2004
Thank you for the quick responses, I really do appreciate it. The boat will be the only thing towed, unless its a Chevy or Ford.
Nice!! Where are you located?
TrainingWheelsWhore™
08 Pro 4X RED ALERT SWB Crew cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a Clipper 1465HST Trail ready pop up. Grumpy Old Man Club http://s3.bite-fight.us/c.php?uid=214743
