Old 05-05-2009, 09:47 AM   #1 (permalink)
Firestone airbags and procomp 6" lift??????????
Hi, everyone today I got my firestone airbags riderite kit in the mail, I tried to install them but looks like the top of the airbag couldn't reach the place where it suppose to be bolt it to. Does anyone has firestone airbag installed with the pro-comp stage 1 lift? It probably needs some kind of spacers between the axles and the bottom of the airbags, but what size spacers and tapered or non tapered type? Any inputs will be appreciated.
2008 titan XE, black on black, 4x4, CC, tow package with big tow mirrors, preferred package, spray on bedliner (SOLD).
2008 Titan Pro-4x, silver with two tone interior, NO Fear Package, 2 degree timing advance.
9sec95autoTT is offline   Reply With Quote
Old 05-05-2009, 09:58 AM   #2 (permalink)
orionS14's Avatar
Re: Firestone airbags and procomp 6" lift??????????
I think you're only option will be to have an aluminum spacer made with a hole in the center...then use a longer bolt for the lower mount.
The spacer should be the same exact thickness as your axle block (rear spacer).
...i.e., if the rear block is 3", have a 3" tall spacer made/machined (same diameter as the base of the airbag), and use a ~4" long bolt instead of the provided 1" long bolt for the lower mount.
I assume the rear bracket will sit in the correct spot, and touches the axle like it should?
- Brian
'05 TITAN CC SE (2" level - Bilstein 5100's - 22" Magnaflow - K&N drop-in - 20" Weld wheels (forged) - 275/60-20 Dueler Revo's)
'96 240SX (turbo'd track car - 325rwhp / 2700lbs)
'07 VW GTI (4-door - DSG - wife's daily driver)
orionS14 is offline   Reply With Quote
Old 05-05-2009, 10:31 AM   #3 (permalink)
Pops's Avatar
Which ones did you get?? Do they have any adapters available??
Firestone Industrial Products Co. ~RIDE-RITE™ Air Helper Spring
I know that Custom Offroad off I-40 and Meridian sells helper springs and can help you get what you need to make them work.
http://www.customoff-road.com/
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 05-11-2009, 07:48 PM   #4 (permalink)
foytiX's Avatar
I had the same problem, you need to order the spacers from firestone for the trucks with the lift. hope that helps.
Jeremy
05 Titan 4x4 6in lift 35x12.5r18 Nitto's____05 Pathfinder 4x4 305/70r16 on 16x8 NO LIFT
foytiX is offline   Reply With Quote
Old 05-11-2009, 11:08 PM   #5 (permalink)
Update: I ordered the spacers and installed the airbags today. So far it's working wonderfully. Thanks for the info
Old 05-19-2009, 07:28 PM   #6 (permalink)
I am looking at installing the Firestone airbags on my '05 Titan and it looks like there is a break line mount on the axle right where the airbags should go. Did anybody have a problem with this? Does someone have a picture of the installed airbag from in front of the axle?
codeman483 is offline   Reply With Quote
Old 05-20-2009, 10:53 AM   #7 (permalink)
orionS14's Avatar
^^^ The lower mount sits about an half-inch above the brake lines...
EDIT: And it's held in place by hugging the U-bolts, and then sandwiched onto the axle with a lower bracket.
It's a well designed kit, for a no-drill option. I would have preferred to drill one hole, rather than use the "J-hook" on the upper mount...but it works well as-is..mounts very solid.
- Brian
Old 05-21-2009, 01:45 PM   #8 (permalink)
Thank you for the input. I actually just got an email from tech support at firestone and they said the same thing. This is all good to know.
Old 08-04-2009, 01:07 PM   #9 (permalink)
Is the lower bracket supposed to fit around the U-Bolts for the leaf springs? My lower bracket looks like it needs to move out toward the leaf spring more but it won't fit around the U-Bolts? Anybody else have this problem?
Black Rhino 20" Keros 20x9 Chrome Wheels - AEM Air Intake - Firestone Airbags - Mats HKINGS Buy/Sell 18 12-23-2008 08:52 AM
Firestone airbags maxxie1 Titan Towing & Hauling 18 12-18-2008 08:49 PM
Black Rhino 20" Keros 20x9 Chrome Wheels - AEM Air Intake - Firestone Airbags - Mats HKINGS Buy/Sell 5 06-25-2008 11:02 AM
firestone airbags----EZ to install?? robby1824 Titan Towing & Hauling 7 05-15-2008 07:08 AM
Firestone Airbags PatrickL Titan General Discussion 12 02-20-2008 11:18 AM
