TitanTalk.com is the premier Nissan Titan Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 06-12-2009, 03:02 PM   #1 (permalink)
new to towing
hey, new to forum and have a few questions about towing with my baby. i have a 06 titan (my baby) with a 6 inch lift im lokking at buying a travel trailer around 26 feet about 7500 lbs full loaded. my truck did not come with the tow package im installing electric brake and receiver my self . now for the question i would love any pointers on towing right down to the most basic. and please all answers titan orientaded thanks
jeremy lippens is offline   Reply With Quote
Advertisement
Old 06-12-2009, 03:20 PM   #2 (permalink)
HRTKD's Avatar
Re: new to towing
Without the tow package you are technically going to pull more than you should. You will need to add relays to the wiring (they plug in) to get all the electrical working right (turn signals, etc).
You will need a heavier duty drop ball mount than the regular duty versions due to your lift and the weight of your trailer. Most drop ball mounts are only rated for 500 lbs tongue weight but the heavier duty ones are good for 750 lbs or more.
Jim
Old 06-12-2009, 03:42 PM   #3 (permalink)
4wheelwhore's Avatar
Re: new to towing
You will be pushing it big time with the lift and non big tow gears, I'm pulling 5500 with the same set up but would not pull any more.
4wheelwhore is offline   Reply With Quote
Old 06-12-2009, 04:41 PM   #4 (permalink)
loufish's Avatar
Re: new to towing
Welcome...
Now the bad news...without the tow gears, you're tow rating is only 7200 lbs, and that's with 32" stock sized tires...I'm guessing you went to 35" tires with your 6" lift...if so then your tow rating went down from that.
The rest is easy, a factory hitch kit is the way to go, it comes with all the extra tow relays needed for trailer lights, the 7 pin connecter and mounting bracket and even the correct metric bolts to mount the hitch on the frame...
Don't blame the Titan, most 1/2 ton trucks without a tow package are at about that rating or less...
PRG Performance Kit w/SAW's
Pro Comp heavy & loud 35" Extreme A/T tires on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
Old 06-12-2009, 06:43 PM   #5 (permalink)
Re: new to towing
then really what kinda trailers can you tow rough guess of what i could tow
Old 06-12-2009, 08:10 PM   #6 (permalink)
Pops's Avatar
Re: new to towing
You'll need to look at 19'-24' Ultra-Lites. They are made out of aluminum and fiberglass instead of wood and aluminum siding. They cost a bit more than the aluminum skin TT's.
I can honestly tell you, there's no way you can comfortably tow that weight of a TT with the little-Tow gears.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 06-13-2009, 06:04 AM   #7 (permalink)
Re: new to towing
thanks guys probably saved me from a big mistake although i am not very happy with my truck at the moment she is still my baby thanks
a towing question and a towing break question disastergrafix Titan Towing & Hauling 12 08-19-2008 07:25 AM
Disappointing Hemi towing experience (from towing forum) karlconnell Titan Towing & Hauling 11 12-19-2007 06:48 AM
05 Towing Capacity? Towing to Central Mexico Invictusklt Titan Towing & Hauling 3 08-04-2007 12:36 PM
9600 lbs towing! try 17000 lbs towing standingtall Titan Towing & Hauling 1 12-08-2005 04:48 AM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 01:03 PM
