Old 06-17-2009, 12:51 PM   #1 (permalink)
Looking at this toyhauler good for the Titan?
2009 Fleetwood Redline Hyperlite - Stock# RD09029 | Southern California RV Dealer | Mike Thompson's RV Super Stores
Pros cons?
BIGGIE is offline   Reply With Quote
Old 06-17-2009, 01:37 PM   #2 (permalink)
Pops's Avatar
Re: Looking at this toyhauler good for the Titan?
That looks sweet. Alot depends on what you're loading into it. The main thing you need to watch for is to keep that hitch weight fairly close to or less than that spec to keep from exceeding the Titan's GVWR. Loading and hitching it up to weigh on a local CAT scale will tell the tale if it's within the Titan's mfg specs.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 06-17-2009, 01:47 PM   #3 (permalink)
54warrior's Avatar
I don't think the Titan's gonna fit in there.
2005 Nissan Titan CC SE 4x4
Old 06-17-2009, 03:08 PM   #4 (permalink)
It fits just have to fold in the BT mirrors.
Only going to be loading at the most 4 motorcycles and a few things to get by for a weekend.
Old 06-17-2009, 08:39 PM   #5 (permalink)
loufish's Avatar
That's going to be a VERY heavy trailer...A GVWR of 9,995lbs and a tongue weight of close to 1,000....That's a lot for a 1/2 ton truck...
Please don't believe the claimed empty weight of 5,505 lbs, try adding about 500 lbs to that....And that's before you load up a single bike or fill the water tank...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-18-2009, 09:52 AM   #6 (permalink)
Any suggestions for a trailer within the wieght limit of the Titan that is a front sleeper toyhauler?
Old 06-18-2009, 09:56 AM   #7 (permalink)
Pops's Avatar
I know that something like a Rage'n 2124C LX can work.
2005 Armada LE 4x4
Old 06-18-2009, 11:21 AM   #8 (permalink)
Pa46's Avatar
Hi !
I just tow this week a 33 feets trailer and i was suprise of my truck , i made more then 300 miles and a never field a sine of lees power form the truck , a have a 2007 SE quad cab , with the tow pak , i just put my swich on in drive 4 and go for it .
Even on gas a use $5.00 more on gas form my tank .
To bee sure ask them for a drive before your purchage the trailer.
PA46
Pa46 is offline   Reply With Quote
Old 06-18-2009, 01:39 PM   #9 (permalink)
I am going to hook up whatever trailer I buy before I buy it. I really have no plans of ever putting 4 bikes in this trailer the water and gas weight is what I am most worried about. I think with a good hitch set up it would be fine but I want to look at all my Front sleeper options befoer I make a big purchas like this
Old 06-18-2009, 01:48 PM   #10 (permalink)
Pops's Avatar
Hey, checkout the Weekend Warrior Superlite Series. They look like they might be a nice option.
Weekend Warrior 2009 Toyhauler Trailers
Model Type Axle Weight #Axle Hitch Weight GVWR Payload Fresh Water Grey Water Black Water
FK2100 Pull 4025 lb. 2 805 lb. 9000 lb. 4170 lb. 100 gal. 30 gal. 30 gal.
FB2100 Pull 4148 lb. 2 815 lb. 9000 lb. 4037 lb. 100 gal. 30 gal. 30 gal.
FS2300 Pull 4575 lb. 2 735 lb. 9000 lb. 3690 lb. 100 gal. 30 gal. 30 gal.
FS2500 Pull 4760 lb. 2 785 lb 9000 lb. 3455 lb. 100 gal. 30 gal. 30 gal.
SS2500 Pull 4760 lb. 2 785 lb. 9000 lb. 3455 lb. 100 gal. 30 gal. 30 gal
SXFK1800 Pull 3445 lb 2 480 lb. 6580 lb. 2655 lb. 30 gal. 30 gal. 30 gal.
SXFB1800 Pull 3460 lb. 2 490 lb. 6580 lb. 2630 lb. 30 gal. 30 gal. 30 gal.
2005 Armada LE 4x4
Old 06-18-2009, 01:52 PM   #11 (permalink)
Weekend worrior is know for guessing really light on the numbers but they are on the list Thanks Pops. I am heading out to look at a few today.
Old 06-18-2009, 05:58 PM   #12 (permalink)
loufish's Avatar
Here is one I've been looking at, it's GVWR is 7800, I wouldn't want to tow more then that...It's a 25 ft front sleeper...
FUN FINDER 245XT TOY HAULER 1/2 TON TOWABLE '09 BLOWOUT:eBay Motors (item 200353729754 end time Jun-24-09 17:36:00 PDT)
Born 9/2004
2002 Honda XR650R
Old 06-21-2009, 09:11 PM   #13 (permalink)
I'll sell you mine. It's got a front kitchen though, and a rear queen bed. Should fit 4 two wheeled motorcycles just fine, and my non-tow pkg Titan hauled it fine. Loaded up with all tanks full and my Teryx inside plus all my gear for a 5-day trip it was 6500lbs. PM me if interested.
2006 Nissan Titan XE C/C - Granite, XE Preferred Pkg, Flowmaster SI/DO Muffler, 2* advance, 2.5" PRG Spacer, Pro-Comp ES9000 rear shocks, chrome door handles.
2008 Carson FL162 Fun Runner Toyhauler
PSNissanFleetMgr is offline   Reply With Quote
Old 06-22-2009, 08:49 AM   #14 (permalink)
Why do you want to sell it?
Old 06-22-2009, 12:41 PM   #15 (permalink)
I never use it anymore. I sold all my toys, and it just sits. It's in nice shape too, and I'll make you a killer deal (way better than those dealerships). PM me if interested.
EDIT: I'l even throw in the brake controller and the WD hitch with it. I just need it gone.
FS: 2008 Carson Trailer FunRunner FL162 16' Toyhauler PSNissanFleetMgr Buy/Sell 22 07-29-2009 01:38 PM
06 Toyhauler F/s jstevens00 Buy/Sell 1 02-26-2008 11:09 PM
Weekend Warrior Toyhauler titansurveyor Titan Towing & Hauling 6 10-06-2007 04:52 AM
2006 Thor Vortex ToyHauler in SAN DIEGO, CA HyperSportRacing Buy/Sell 0 07-12-2007 03:43 PM
poor titan!!! for those with weak stomachs dont look!!!! good bye titan!! dtowntitan Off-Topic Discussion 35 03-30-2007 06:46 AM
