Old 06-29-2009, 06:52 AM   #16 (permalink)
loufish's Avatar
Re: more advice on hauling 29' travel trailer
I am asking you these questions because I don't know anything about towing but this is about a friend of mines setup that i was concerned about because I knew something here is not right. This is his comment below on this setup from his research. What do you think?
Allright...Let's do your Titan and the Hornet Trailer...
Your Titan is rated to tow about 7400 lbs(provided you have LT tires)
Your Titan has a payload rating of about 1500 lbs (remember the hitch weight of about 75-100 lbs comes right off your payload number)
Your Titan has a GVW of about 6400 lbs.
Your Titan has a Combined Gross Weight Rating(loaded truck & trailer weight) of 12,800 lbs(still need LT tires)
Your trailer has a GVWR of 7620, and a tongue weight of about 760 lbs(based on a standard of 10)
After hitching up, your truck will have about 750 lbs of payload left over.
.This is your weight envelope..
This would be the conclusion:
If you load up your truck up to its max GVW, you have about 6400 lbs of CGVW rating left over, your trailer loaded up to it's GVW(minus the tongue weight) will be about 6850 lbs, so on paper you're about 400-500 lbs over the CGVW rating...
Basically you're on the hi-end of all your rating(provided you have the correct tires)
So after all that we're right back to my OP:
You'll be at the max....unless you plan on towing a empty trailer...
Tow in 4th gear, drop to 3rd on hills & grades...
We cool?..........
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-29-2009, 03:59 PM   #17 (permalink)
thanks for clarifying that.
japtitan is offline   Reply With Quote
Old 07-04-2009, 05:30 PM   #18 (permalink)
Originally Posted by japtitan View Post
Hi everyone , i own a 2006 titan Crew XE 2948KG towing cap 6500 lbs. I just bought a 29' travel trailer weighing 4888 lbs. dry. Will i be putting strain on my truck and engine? What will I need to pull it safely without hurting my truck. Also what gear do I need to pull it, obviously a hitch. (rated) ?
thanks
that doesnt sound good at all, why would you want to use your titan that close to its limits??, youll eventually hurt it
black08 is offline   Reply With Quote
Old 07-04-2009, 10:54 PM   #19 (permalink)
loufish's Avatar
For almost every guy towing theres 2 camps...
1) My truck is rated to tow x,xxx lbs so there should be no problem doing so, and the manufacture should already have a safety factor built in.
2) Why kill my truck, so I'll tow no more then 75-80 percent of it's rating and my truck will last a little longer....
I'm not going to bag on the camp I'm not in, but IMHO I just don't believe in towing at 100% except for short tows...And I'd feel the same way if I had a 3/4 ton truck, too much trailer for that and I should be looking for a 1 ton truck...
Where things in my mind get real sticky is too much length.... A 33 ft trailer is a whole lot of tail wagging the dog for a 1/2 ton truck...
Born 9/2004
2002 Honda XR650R
Old 07-07-2009, 08:13 AM   #20 (permalink)
were on the same page, everyone believes that since the manufacturer tell you itl tow , 10, 000lbs, that its safe to do so. maybee across town and thats it,. put those big trailers on a highway or mountain road and it can become dangerous, and also, are these people towing these big a%&trailers really set up for it, how do your brakes feel wit 8k lbs behind them?? take a look at the leaf springs sprung to their limit. 1/2 tons , no matter if thier 400 hp or not, still are not a heavy duty machine, none of them. any one who doesnt beleive me just needs to look underneath a ford f 250, or a 2500 chevy, or better yet, tow ur 30 foot trailwer with a titan and then w/ a 2500, the difference is huge.
Old 07-07-2009, 11:08 AM   #21 (permalink)
RobKar's Avatar
Maybe you could reread what you wrote after having that many beers it could help?
Here is the deal. I have an F250 and an Excursion 3/4 ton and then there is my Titan. Guess what ... My Titan out tows my Excursion and is very close to the F250. I cant get everybody in the F250 so I use my Titan.
My TT is 29ft and ~ 8000 loaded.
AKA TrollopInTraining™ AKA chinawhore™
2005 CC LE
My wife thinks I spend to much on my truck!!
My Train Horn <-- Listen
RobKar is offline   Reply With Quote
Old 07-09-2009, 03:52 PM   #22 (permalink)
Robkar is your titan a big tow?
Old 07-09-2009, 04:12 PM   #23 (permalink)
Pops's Avatar
FWIW, your "friend" is an idiot and shouldn't be talking that way to you. Let the idiot ruin his truck, it'll decide it's had enough one day. I think I've seen RobKar post that his LE is BT. You might run a search on his posts to confirm.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 07-09-2009, 09:03 PM   #24 (permalink)
RobKar's Avatar
Yep its 2WD with Big Tow. So its my locomotive in the train I have, and pulls like one too...
2005 CC LE
Old 07-09-2009, 09:34 PM   #25 (permalink)
This is a painful thread to read.
Essentially Stock 2006 SE 4WD with Bilstein HD's
Security System: Glock
12glocks is offline   Reply With Quote
29' travel trailer japtitan Titan Towing & Hauling 15 07-04-2009 06:07 AM
New Travel Trailer Pops Titan Pictures & Media Post 14 04-28-2009 08:19 AM
Travel Trailer Hauling tatitan Titan Towing & Hauling 13 09-15-2006 01:45 PM
Anyone ever lift their travel trailer? CoachBoone Titan Towing & Hauling 16 06-05-2006 01:59 PM
Need Travel Trailer Advice.... JetTech Off-Topic Discussion 6 05-23-2004 11:40 PM
