Old 06-26-2009, 01:03 PM   #1 (permalink)
Do I have Big tow or not?
I recently bought my 04 titan from a used car lot. The salesman didn't know much about the truck other than the miles, color, etc...
After researching a bit and reading countless threads on this site I think I have the big tow but I'm not sure.
Is there a way to tell for sure? Sticker in the door? Specific gauges? anything?
I just ran into a screaming deal on a 29' travel trailer and am wondering if I need to do anything special to the truck to pull it, or if the stock will work.
govandals is offline   Reply With Quote
Old 06-26-2009, 01:05 PM   #2 (permalink)
beason's Avatar
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
Re: Do I have Big tow or not?
the BT has the big mirrors, a trans temp gauge, hitch, trailer lights plug in the bed, and mine has a "towing mode" button on the dash.
  • 06 Galaxy Black LE Crew Cab BT.
  • air box mod
  • Armada air dam
  • Aries stainless step rails
  • Power Acoustik REACT1-1100 Class D2 1100-Watt Mono Amplifier with dual 10" kicker cv-r subs
  • Dick Cepek DC-1 18" chrome wheels
  • Flowmaster 50 dual in/out dumped.
Soon to have: 2" drop shackles, Jet Tech mod, tinted tails, CAI.
beason is offline   Reply With Quote
The Following User Says Thank You to beason For This Useful Post:
govandals (06-27-2009)
Old 06-26-2009, 01:13 PM   #3 (permalink)
Juday's Avatar
The first give away will be the mirrors. If you have big tow, your mirrors will look like this:
Another feature will be the transmission temperature gauge:
If you have the Off Road Package, the gearing will be the same as the Big Tow package.
35x12.5x17 Cooper Discoverer STTs
AEM Brute Force CAI
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
PowerSlot Cryo Rotors w/ Hawk LTS pads from Frozen Rotors
Superchips Cortex
The Following User Says Thank You to Juday For This Useful Post:
Old 06-27-2009, 01:40 PM   #4 (permalink)
Thanks for the help guys! I have the mirrors and the gauge, the lights in the bed and all the other things listed.
Looks like I am going camping next weekend!
Old 06-28-2009, 08:46 PM   #5 (permalink)
Learjet's Avatar
I would make sure you add, if someone has not done it already, the finned aluminum differential cover and change the diff fluid to what is required now Synthetic 75w-140.
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 06-28-2009, 08:51 PM   #6 (permalink)
BiggMike's Avatar
Send a message via Yahoo to BiggMike
I have an 09 with the Big Tow package w/o the mirrors. I have seen a lot 09's that come that way.
BiggMike is offline   Reply With Quote
Old 06-28-2009, 09:47 PM   #7 (permalink)
loufish's Avatar
A very good idea!...Even if you can't get your hands on a factory finned cover right now, I'd drain & refill the rear end oil...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-29-2009, 09:52 AM   #8 (permalink)
mjw357's Avatar
For an '04 the trans temp guage is a sure sign that the truck has BT package, the mirrors and hitch can always be added. All titans have the tow mode button and aux. trans cooler.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 06-29-2009, 09:58 AM   #9 (permalink)
Juday's Avatar
Also, if you want to make certain you have the BT package, crawl underneath your truck and take a look at the rear differential. There should be a sticker placed on the bottom that will read what the gear ratio happens to be.
Big Tow ratio will be 3.357
Non Big Tow will be 2.94
AEM Brute Force CAI
2* Timing Advance
Superchips Cortex
Old 06-29-2009, 11:13 AM   #10 (permalink)
Sorry I'm a noob, I am thinking I already have the finned diff cover - is this it?
And is there a way to check on the diff fluid without just replacing it?
Old 06-29-2009, 11:50 AM   #11 (permalink)
Learjet's Avatar
yes that is the cover you want.
If you want to check the fluid level the plug on the finned part is where you check it from. The level should be close to that plug level.
I would change the fluid and start fresh...
Just pull the bottom plug, which has the magnet on it. You will see sludge on the plug, but hopefully no chunks of gears. Clean and Replace the plug and fill thru the top fill plug with @ 2.2 qt's of your favorite Synthetic 75w-140. It is that easy, and should be done every 30,000 miles if you tow per the manual. RTV on the threads of the plugs is recommended.
I do mine every year because it is so easy to change.
Born 5/06
big tow non big tow rearend swap questions. nascarjody Titan General Discussion 3 06-18-2009 03:18 PM
Wanna trade my big tow le mirrors for your non-big tow le's nicojames Buy/Sell 5 11-28-2008 07:37 AM
Big Tow vs No Big Tow..REDUNDANCY ALERT!!! maestro Titan General Discussion 20 06-20-2005 09:30 AM
Survey Hy MPG Big tow--vs-no Big tow PHOEBISIS Titan General Discussion 73 07-13-2004 03:52 PM
RPMS at 60 MPH-BIG TOW VS no Big Tow??? PHOEBISIS Titan Performance Modifications 17 06-30-2004 10:18 PM
