Old 07-03-2009, 02:25 PM   #1 (permalink)
Left signal on trailer doesn't work
I have a 04 w/the tow package and the left blinker on the trailer is the only light that doesn't work. The brake and running light on both sides work fine. Does the left signal have a fuse all to itself?
Where should I start?
tia
osumason is offline   Reply With Quote
Old 07-03-2009, 05:39 PM   #2 (permalink)
loufish's Avatar
Re: Left signal on trailer doesn't work
If the left trailer brake light works, but the left trailer turn signal doesn't, you have BCM (Body Control Module)issues.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Trailer Left Turn Signal/left brake light not working bclmread Titan Towing & Hauling 66 01-06-2009 04:40 PM
left rear turn signal doesn't work titanfarmer Titan Problems & Dealer Service 2 03-15-2008 10:18 AM
Same ol' left signal/trailer light issue NOHEARTBEAT Titan Towing & Hauling 4 03-12-2008 10:47 PM
Trailer right turn signal problem Txsbigfoot Titan Towing & Hauling 5 08-13-2007 10:57 AM
trailer rt turnn signal inop mytitan Titan Towing & Hauling 9 02-25-2007 02:51 PM
