Old 07-03-2009, 08:47 PM   #1 (permalink)
Electrical problem with brake controller
I have read most of the posts and havent seen this problem Iam experiencing... I have an 06 titan with the BT package. I purchased a primus brake controller by Tekonsha, wired it into the nissan harness that plugs into the elec. brake controll plug-in under dash. Everything seems straight forward but now it says it is connected when there is no trailer. When a trailer is plugged in it still says connected but the trailer brakes do not work(trailer brakes work fine when plugged into chevy, not prob. with trailer). All trailer lights work properly. Some times it says it is disconnected when you plug a trailer in. While towing if you turn on driving lights the controller says trailer is disconnected. Now for a new twist, the brake lights (truck) stay on no matter what, this happened about a week after controller install. I cannot get brake lights to turn off, had to disconect battery. All relays are there, not sure if they are functioning properly however. could this be it? something else? anyone else had this problem?
Thanks for your help I need it!
mxracer450 is offline   Reply With Quote
Old 07-04-2009, 10:45 PM   #2 (permalink)
loufish's Avatar
Re: Electrical problem with brake controller
Did you run the adapter harness from Tekonsha, or did you wire it up?....You might have some crossed connections...
Check all that first...
You might have a bad controller back feeding the truck brake curcuit...or issues above...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 07-06-2009, 07:31 AM   #3 (permalink)
mjw357's Avatar
Well start by unplugging the brake controller. If your brake lights (truck) go out, there is a crossed connection somewhere (as Lou stated).
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 07-06-2009, 05:06 PM   #4 (permalink)
Well I ungplugged the harness and now the check engine light turned on and its running in safe mode (slow acceleration). Sooo I just dropped it off at the shop =(. NE who Ill let ya know what they find.
Old 07-08-2009, 08:37 PM   #5 (permalink)
So here it is, semi simple as I expected... The lights stayed on because the wire was pinched when I put the lower dash panel back on(my bad). Trailer controller had to be completely rewired to rear plug in. For those tow weiry I just towed a 7000 # TT up Teton Pass (do a search) 10% grade and very long... Very impressed compared to other 1/2 ton trucks I have pulled trailers up pass with less.
Electrical Problem govandals Titan General Discussion 9 07-02-2009 12:15 PM
Brake controller problem. titanmike Titan Towing & Hauling 2 04-26-2009 07:22 PM
Possible Electrical Problem 703titan Titan Problems & Dealer Service 3 01-08-2008 02:13 PM
Electrical Problem?? JB Titan Titan Problems & Dealer Service 1 11-19-2007 07:37 PM
Electrical Problem goinhtn Titan General Discussion 3 03-14-2006 12:01 AM
