So today I was at my local fair and they had a truck pull. Well they had a stock truck class so I figured I'd see what the old titan could do. Well I put it in 4 Low and hit the gas, my Slip light came on and never shut off not alowing my tires to spin. Is there a way to disable this? I can not find a button anywhere for this. Is this just traction control ?
08 Pro 4X RED ALERT SWB Crew Cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a 07 Clipper 1465HST Trail ready pop up, and "Cartzilla" Grumpy Old Man Club http://s3.bite-fight.us/c.php?uid=214743
If you have the e-locker (sounds like you don't) then when you engage that then the VDC or ABLS systems are disabled.
So how did you do in the truck pull?
Jim
I got 204 Ft. Not bad I guess. The rpms would not go over 3k. It was all fords, dodges, and chevys and I wanted to do good so bad! Next time around I will If i can get this figured out.
My understanding is that the burnout mod is for when you want to hold the brake and accelerator on without the ECU knowing that both of them are on. So I'm not sure how the burnout mod is going to help you out with your truck pull.
Jim
2008 Galaxy Black CC Pro4X,Weather Tech in channel vent visors ,Tinted front windows,
Grillcraft Black Mesh Grill.S&B cold air intake,
TBS screen removed,Bullydog Powerpup,
New Transmission,Magnaflow cat-back,
Magnaflow X-pipe,Magnaflow cats
secondary cats removed with custom pipes,
Cooper STT Tek 3 325-60-18, Beautiful Pro4x sticker for all the haters is now gone.
and beleav me i took my o4 titan with bfg all terane's on a pull and went well beond what any of the chevy's, doge's, and ford's went the only thing that beat me was a yoda with biger tiers and he wasnt exatly stock all terane eather
Yeah i dont have a VDC switch on my 06 LE. Is there any way to find the wires and wire in a switch like you do with the burnout mod? It is very aggravating when you kick the *** end out and your rpm's get sucked down and the tires stop spinning...
What you are describing is not the ABLS. When my slip light is flashing I can bury the tach. What you are describing is VDC. All the ABLS does is apply the break to which ever tire is spinning fastest. If both are spinning at the same speed ABLS does nothing, it will also not put the brake on the tire that is spinning slower.
I came into this world naked, screaming and covered in someone else's blood I plan on leaving this world the same way.
