Old 07-20-2009, 02:58 PM   #1 (permalink)
Bulldog22's Avatar
after market trans cooler?
I have an 08 titan and tow approx 9200lbs. I have plenty of power and tires fixed my sway problem. However, after about 70 miles straight towing, my transmission starts down shifting when it shouldnt. I think the transmission cooler is not doing enough. Have any of you got an after market cooler and did it help. I plan to take my toy hauler to the Arkansas Mountains this fall and dont want to destroy my transmission.
Bulldog22 is offline   Reply With Quote
Old 07-20-2009, 03:03 PM   #2 (permalink)
Carbeaux's Avatar
Re: after market trans cooler?
Are you on the lower gears? Towing in 4th and downshifting if you're climbing hills and find that the tranny starts "hunting" for gears? 9200 lbs is right up there at the max for this truck, so 4th gear and downshifting when needed would be a must.
Direct answer to your question is that I haven't added an extra cooler, but haven't needed it for the 6500 lbs that I tow.
Hook 'Em Horns!
Old 07-20-2009, 03:21 PM   #3 (permalink)
titanss's Avatar
Here you go: Tranny Cooler Added Long TruCool 4588 - Nissan Titan Forum: Club Titan Forums
Or you can get this: YourCovers.com Nissan RE5-R05A Deep Transmission Pan for Titan Trucks
2004 XE KC
Quickest UnTuned Titan: 13.900@96.67mph
Old 07-20-2009, 03:23 PM   #4 (permalink)
Yahooligan's Avatar
What gear are you towing in? At what RPMs and what kind of hill is it downshifting on that you think it shouldn't? What makes you think the trans cooler will help? You have a trans temp gauge right there in your dash (right? I'd hope so if you're towing 9200lb), if it's not getting hot then a cooler won't make any difference. The Titan already has a transmission cooler, btw. Actually, 2 if I remember right.
We need more specifics. Downshifting frequently or hunting is a symptom of towing in the wrong gear, not of a trans running hot.
The dog: 2005 Titan SE CC 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, Roadmaster Active Suspension, SnugTop Sport shell, 5000k HIDs
The fish: 1984 Scarab 21SS - Marine Power 454 - FOR SALE
Yahooligan is offline   Reply With Quote
Old 07-20-2009, 06:44 PM   #5 (permalink)
Learjet's Avatar
your cooler is fine !
Tow in 4th and go 65 mph max. Grab 3rd, or lower, up long grades.
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 07-21-2009, 05:26 AM   #6 (permalink)
Bulldog22's Avatar
I usually run in tow mode and leave it in 4th the entire trip. When I put it in drive it jumps back and forth too much. It tows great in 4th, it will just start down shifting to 3rd when there is no incline at all after about 60 miles or so. 9500 is my max tow capability. My toy hauler is only 5800 lbs dry, but I carry three atvs, and a MX bike, also gear and 112 gallons of water and 25 gallons gas, all that gets me up to around 9200. I am debating on adding a leaf to the rear. Ive already put 10 ply tires, that got rid of almost all of the sway. I do try to stay at 65. No complaints though. I dont think any other 1/2 ton truck could do what I do.
Old 07-21-2009, 05:54 AM   #7 (permalink)
mjw357's Avatar
Bulldog, looking at the pic of your truck, not sure if you have big tow package or off road? You may not have the lower gears (1:3.36). That is will affect your towing performance quite a bit in the hills.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
The Following User Says Thank You to mjw357 For This Useful Post:
Bulldog22 (07-21-2009)
Old 07-21-2009, 06:02 AM   #8 (permalink)
Bulldog22's Avatar
Correct. I didnt get the "tow package" I wasnt aware that the gearing was different with the tow package. I thought it was just the mirrors and trans gauge. I am going to add a leaf spring next week and get the cold air intake. The trip I am taking this fall is only about 7 hours, so I think it will be alright. I usually stay in Louisiana. The hills here are not very bad.
Thanks
Old 07-21-2009, 07:50 AM   #9 (permalink)
Learjet's Avatar
That is your problem, too much weight for a non-big tow truck
Born 5/06
Old 07-21-2009, 08:13 AM   #10 (permalink)
Bulldog22's Avatar
That is why I may get an aftermarket cooler. The truck is an 08, cant get a new one for at least two more years. I think I will suck it up for two more. A friend works at Nissan in Tennessee. He saw the 2011 3/4 ton they are trying to build. I want to wait for that one. I heard they may do a diesel.
Old 07-21-2009, 08:18 AM   #11 (permalink)
NBhunter80's Avatar
You are overloading your truck. I can't see any way you can tow that much without exceeding the weight limitations on the rear axle and rear tires. If I were towing 9200 pounds I would buy this or similar:
Used 2008 Dodge Ram 3500 Lone Star Quad Cab 4x4 Dually for Sale | DealerRevs.com - Dealer Car Ad #10837248
This one is even for sale local!
2005 LE King Cab 4x4 Offroad pkg Big Tow, Purchased used on 2008/11/30.
Silver with charcoal leather interior, black Nissan OEM brush guard, 285-70-17 BFG All Terrain T/A KO's on OEM OR 7-spoke 17" rims, 2 degree timing advance, Magnaflow 14" SI/SO muffler on stock pipes with 12" T304 stainless double-wall tip, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
Future mod wish list:
6" Procomp stage I lift, SAWs, TC UCAs, 35x12.5x20's on 20X10 wheels
CAI, headers, catback exhaust
Bushwacker pocket style flares
Custom paint job over this OEM crap!
NBhunter80 is offline   Reply With Quote
Old 07-21-2009, 11:00 PM   #12 (permalink)
loufish's Avatar
To the OP:
This is your first truck, right?
You are towing WAY TOO MUCH for those pitiful 2.94 rear end gears! I'm really suprised you aren't in 3rd gear just about all the time on the open road...
Even diesels would dare run that ratio and they've got bu-koo torque....
I would really consider hitting up a wreaking yard and swap in a 08' tow package or off-road package rear end....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 07-22-2009, 12:24 AM   #13 (permalink)
Yahooligan's Avatar
Tow package or not, the Titans have the same cooling setup. An aftermarket cooler won't help, the root of the problem is your axle ratio and this is why it downshifts so much. Tow in 4th and downshift to 3rd if it's hunting too much. Don't tow in D, especially with how far over the tow limit of the truck you are.
The max tow capacity for your truck is 6500-7400 pounds, depending on which trim you have (XE, SE, LE). At best you're 1800lb over the limit, worst case you're 2700lb over the limit. The 9500lb limit is *only* for a short-bed, King cab, 2wd, XE or SE with the tow-package. Anything other than that will have a lower tow limit, that limit depends on a number of variables.
It's time to focus on something other than an aftermarket trans cooler to solve your problems.
Old 07-22-2009, 09:35 AM   #14 (permalink)
Learjet's Avatar
here is a pic of the cooler you have hidden between the Radiator and the AC condenser, once again it is plenty big enough.
Born 5/06
Old 07-22-2009, 03:54 PM   #15 (permalink)
JJenkins's Avatar
Lets hear more about this
JJenkins is offline   Reply With Quote
The Following User Says Thank You to JJenkins For This Useful Post:
TitanBlue (07-22-2009)
ipt trans cooler firelife25 Titan Performance Modifications 6 01-08-2009 08:47 PM
Trans cooler? scwoody Titan Engine, Transmission & Drivetrain 13 05-23-2008 08:02 PM
Trans cooler Line leak ??? KnoxTITAN Titan General Discussion 3 08-24-2007 03:02 PM
stillen's trans cooler? foytiX Titan Towing & Hauling 0 12-18-2006 07:24 PM
Trans Oil Cooler rholland Titan Problems & Dealer Service 8 01-24-2006 03:35 PM
