Old 07-24-2009, 07:22 PM   #1 (permalink)
door mirror single arm mount change to dual arm mount
Hello All;
I have a 2004 Nissan Pathfinder Armada. I have been towing a 20ft trailer with it and it is very difficult to see behind the trailer. Does anyone know if the Dual arm mount (big tow pkg), electric, w/memory can replace the single arm mount, electric, w/memory door mirrors.
Will almost any year of the dual arm mount mirror replace the single arm mount, or am I stuck with the single arm mount?
Any information is appreciated.
Thank you.
JohnGoutbeck is offline   Reply With Quote
Old 07-25-2009, 04:09 AM   #2 (permalink)
Re: door mirror single arm mount change to dual arm mount
Yes, you can put Big Tow mirrors on an Armada.
2006 Nissan Titan XE C/C - Granite, XE Preferred Pkg, Flowmaster SI/DO Muffler, 2* advance, 2.5" PRG Spacer, Pro-Comp ES9000 rear shocks, chrome door handles.
2008 Carson FL162 Fun Runner Toyhauler
PSNissanFleetMgr is offline   Reply With Quote
Old 07-27-2009, 08:17 AM   #3 (permalink)
Thnak you for the information.
Next question about the Big Tow Mirrors. About how much farther do the Big Tow Mirrors (dual arm) stick out compared to the regular single arm mirrors on the Armada (or for Titan)? I have a smaller garage and with the regular non-Big tow mirrors, I have only about 4-6 inches clearance.
Thank you.
Old 07-27-2009, 08:21 AM   #4 (permalink)
Rhino404's Avatar
Thank you.
They are adjustable...just pull them in when you need to park in the garage.
Rhino404 is offline   Reply With Quote
Old 07-27-2009, 08:22 AM   #5 (permalink)
mjw357's Avatar
They manually fold in too, if need be.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 07-27-2009, 08:32 AM   #6 (permalink)
Blackbeauty's Avatar
One thing to note... You need to swap out per your trim level...
If you have an SE, you need to get the SE Big Tow mirrors.
LE, get the LE Big Tow mirrors.
It matters as the LE have more functions such as heat, power, etc.... The lower trim levels don't come with the ability to connect to the LE functions... so stay within your trim level.
Old 07-27-2009, 08:59 AM   #7 (permalink)
Pops's Avatar
The SE/LE do not matter on the Armada. The only options are memory or non-memory, everything else is standard. I changed mine out and the BT mirrors do help a bit.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 07-28-2009, 09:16 PM   #8 (permalink)
That is one sweet Armada, Pops. I like it.
The Following User Says Thank You to PSNissanFleetMgr For This Useful Post:
Pops (07-29-2009)
Old 07-29-2009, 09:22 AM   #9 (permalink)
Pops's Avatar
Thank you sir.
Since I also have an F150 now, my neighbors have been asking if I got it to pull the Travel Trailer with. I answer "no, it can't pull the travel trailer, the Armada tows a whole lot more than the Ford can". It's hilarious to watch the confusion show up on their face then I say, "but the Ford can pull a boat if I get one later since pulling doubles is illegal here" then they get this 'Ahhhhh' expression. The typical SUV stereotype cracks me up.
Sorry John for the hijack. PM me if you want to know where I got my mirrors from, the price is tough to beat.
2005 Armada LE 4x4
Old 07-30-2009, 08:13 AM   #10 (permalink)
Thank you for all your help and information. Its great to know ther is a wealth of information out there from owners and others.
Since I have the Armada LE with chrome covered mirrors, I hope to find chrome covered dual arm mirrors. I know they are out there. I have found the left side near here and the right side farther away.
The dual arm mirrors are costly but they will do the job and keep the Armada looking sharp.
Thank you for all your help and advice.
Have a good day.
Old 07-30-2009, 08:28 AM   #11 (permalink)
Pops's Avatar
John, I picked mine up from a dealership here for $320. Check your PM's.
2005 Armada LE 4x4
Upper control arm hitting shock mount basanch73 Titan Problems & Dealer Service 3 10-23-2007 04:34 PM
tc a-arm install help/how-to Voodoo Titan Suspension 4 03-12-2007 09:44 AM
a-arm question? cafirefighter Titan Suspension 5 07-07-2006 06:54 AM
Titan radio mounts metra scoshe--1 ISO singele mount, and 1 scoshe double din mount smoketitan Buy/Sell 9 04-03-2006 11:21 AM
