Old 08-05-2009, 10:01 PM   #16 (permalink)
Re: Rear sag concern.
Alti03,
The RAS XXL system helped the sag in my Titan when towing our TT. It is a 7500+ lbs. We hooked it up the first time to the WD hitch, put the load on and it dropped about 1" and then just stopped dropping. My father and uncle were both amazed at the engineering in the RAS -- beauty in it's simplicity, and it just works.
I agree that the trailer was probably "askew"... but the RAS sure wouldn't hurt you.
-S
2009 King-Cab SE, Blue
//Factory//
Max Utility Package | Popular Equipment Package | Floor Mats | Splash Guards
Mods:
//Performance & Towing//
Prodigy Brake Controller | Roadmaster Active Suspension (heavy-duty version) | Amsoil Ea Air-Filter | Amsoil Signature Series 0W-30 Motor Oil | Amsoil Ea Oil-Filter | Amsoil ATF | Amsoil Severe Duty Front/Rear Diff Lube
//Exterior//
Ventshades & Bugflector | Chrome Door Handles and BT Mirror Caps | Extang Tri-Fecta Tonneau | Westin Platinum Series NerfBars | Silverstar Ultra-II (Hi/Low Beams) | BF Goodrich All-Terrain T/A KO
//Interior//
Windows Tinted | WetOkole Seat Covers (Front) | Boston Acoustics 6.5", 3-Way Rear Speakers | Boston Acoustics 6.5" Component Speakers in Front w/1" Tweets in Dash | Boston G1 10" Sub in rear underseat enclosure (from Tech12Volt) | XM Satellite Radio | Wi-Ex Cellular Booster
More to come...
SHoffman is offline   Reply With Quote
Old 08-19-2009, 11:52 PM   #17 (permalink)
Originally Posted by SHoffman View Post
Alti03,
-S
I agree, I think the Ras system is my best bet. Airbags are nice but kinda overkill for the once in a while tow.
alti03 is offline   Reply With Quote
Old 08-27-2009, 07:51 PM   #18 (permalink)
Did you tow the vehicles on a flat bed trailer? If so, try turning the car around. I did a haul to AZ once with a Mustang from work for an out of state buyer and when I loaded the car facing forward the tongue weight was sky high and the headlights of my truck shined at the Big Dipper. I turned the Mustang around (backed it onto the trailer) and it towed like a charm.
2006 Nissan Titan XE C/C - Granite, XE Preferred Pkg, Flowmaster SI/DO Muffler, 2* advance, 2.5" PRG Spacer, Pro-Comp ES9000 rear shocks, chrome door handles.
2008 Carson FL162 Fun Runner Toyhauler
PSNissanFleetMgr is offline   Reply With Quote
Old 08-27-2009, 08:26 PM   #19 (permalink)
Learjet's Avatar
www.timbren.com Just put some on my T for $195
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Tags
salstats is, the new adamdude
Transmission concern - is this normal ? speediq99 Titan Engine, Transmission & Drivetrain 1 04-14-2007 10:09 PM
Rear Spring Sag Unloaded RobKar Titan General Discussion 6 06-15-2006 06:24 PM
Anybody have problems with rear susp sag? Kong Titan General Discussion 2 03-30-2005 10:11 PM
Rear sag while towing...... DStewart Titan Towing & Hauling 27 01-28-2005 02:56 PM
To whom it may concern... admorris Titan General Discussion 33 12-16-2004 08:17 AM
