Old 07-28-2009, 10:54 AM   #1 (permalink)
lifted tian and towing
i know this has been covered in terms of lifted trucks and towing, it seems as though i should have no problem with what i tow but i want to make sure. i'm going to lift my truck 6" and put it on 35's. i have the big tow on my 06 cc se. i tow a 2 place clam shell trailer with 2 snowmobiles in it. once in a while i put a third sled in the bed of my truck. i know the lift and tires will hurt alittle but i should be okay correct? i see guys pulling 7k trails with a lift, mine can't be more that 2500-3000lbs. the trailer is aluminum weighing maybe 1200 lbs and the sleds fully gassed weight maybe 650lbs each. i just don't want to break things, i can deal with not driving 90 mph on the highway to get to the trails.
tbeaton is offline   Reply With Quote
Old 07-28-2009, 09:14 PM   #2 (permalink)
Re: lifted tian and towing
You should be fine. I had a 6.5" lift and 35's on my Titan and pulled my 6500lb. toyhauler all over the state. The mileage sucked ***, but the truck did fantastic.
2006 Nissan Titan XE C/C - Granite, XE Preferred Pkg, Flowmaster SI/DO Muffler, 2* advance, 2.5" PRG Spacer, Pro-Comp ES9000 rear shocks, chrome door handles.
2008 Carson FL162 Fun Runner Toyhauler
PSNissanFleetMgr is offline   Reply With Quote
Old 07-29-2009, 08:55 AM   #3 (permalink)
okay cool.
Old 07-29-2009, 11:15 AM   #4 (permalink)
Pops's Avatar
I've been pulling my 6500-lbs TT just fine, my tires are still 33's. 3,000-4,000 lbs is barely noticeable behind these trucks.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 07-29-2009, 11:49 AM   #5 (permalink)
bills1974's Avatar
Send a message via AIM to bills1974
I pull my 6k lbs. boat almost every weekend, half the time, I forget it's back there...
2008 Titan SE CC, Popular Package, Big Tow, Bed Utility Package, Sliding Bed Extender
Click here to see my mods
Click here to see my pics
Wife's Ride: 2005 Infiniti QX56 4x4
My Other Ride: 2007 Sea Doo Speedster 200
AKA: Crossdresser Whore™
The Bald Avenger®
"Why is the rum always gone?"
bills1974 is offline   Reply With Quote
Old 07-29-2009, 12:12 PM   #6 (permalink)
so mine should be a breeze even with the larger tires. i'm more worried about breaking things. i have had the rear end problems like most but have also had the front end go and the front drive shaft. i'm concerned about the added stress thats all. i know the truck has the balls to pull it.
Old 07-29-2009, 12:28 PM   #7 (permalink)
Pops's Avatar
As long as the trailer's hitch weight is less than 900-lbs, you'll be fine.
If you think that you're worried, you should've seen me looking into if the Armada's IRS could handle an 800-lbs hitch weight AFTER I already bought the Travel Trailer. I was sweating if I screwed up or not because NOONE uses a Lifted Armada to pull a Travel Trailer, but it's all good to go. - hehe
2005 Armada LE 4x4
Old 07-30-2009, 09:31 AM   #8 (permalink)
i don't know how much the hitch weight or tongue weight will be, but you can move these small sled trailers around very easily by hand.
Old 07-30-2009, 09:37 AM   #9 (permalink)
Pops's Avatar
You're not gonna have any problems then. My tongue jack snapped a 2x6 in 1/2 when I tried to use a board under the foot.
2005 Armada LE 4x4
Old 07-30-2009, 09:48 AM   #10 (permalink)
NBhunter80's Avatar
That tow weight should not give you any problems. You will probably have more stress from simply adding 35's and lifting then you would from towing that weight. Honestly, you will be under 3000# total weight, and if you load the proper 10% tongue weight you should not have any problems even in a non-bt Titan. Good luck!
2005 LE King Cab 4x4 Offroad pkg Big Tow, Purchased used on 2008/11/30.
Silver with charcoal leather interior, black Nissan OEM brush guard, 285-70-17 BFG All Terrain T/A KO's on OEM OR 7-spoke 17" rims, 2 degree timing advance, Magnaflow 14" SI/SO muffler on stock pipes with 12" T304 stainless double-wall tip, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
Future mod wish list:
6" Procomp stage I lift, SAWs, TC UCAs, 35x12.5x20's on 20X10 wheels
CAI, headers, catback exhaust
Bushwacker pocket style flares
Custom paint job over this OEM crap!
NBhunter80 is offline   Reply With Quote
Old 07-30-2009, 02:23 PM   #11 (permalink)
I have bt, so i'm not worried anymore, seems like i should be able to rip this baby with little effort, just some extra gas.
Old 07-30-2009, 02:29 PM   #12 (permalink)
Pops's Avatar
Keep in mind that too much weight behind the trailer axle creates sway. If it starts to sway at all, even at 60-mph, stop and move more weight to in front of or on top of the trailer axle.
Also make sure that you have a big enough drop shank to keep the trailer horizontal. My shanks are all 6" drop. Other than that, you shouldn't even be able to tell it's there.
2005 Armada LE 4x4
Old 07-31-2009, 11:11 AM   #13 (permalink)
i will be sure to get a larger drop. the sleds really can only sit in one place on the trailer, the are held down with ties that sit in specific spots. i can probably only move the 5" front to back.
Towing with a lifted non-big tow titan 4wheelwhore Titan Towing & Hauling 10 02-04-2009 10:51 PM
Towing with lifted Titan backdoc7 Titan Towing & Hauling 14 01-27-2007 10:41 AM
? for lifted Titan owners.After you lifted did you have problems with backup sensors? Waterfowler Titan General Discussion 11 09-06-2006 12:08 AM
Who's lifted and still towing??? Chris93Si Titan Suspension 23 04-22-2006 02:39 PM
Test Drove Tian & F150 back to back. HSrider Titan General Discussion 12 01-26-2006 12:00 PM
