Re: Can I tow this without an issue?
It would be nice to have trailerbrakes, but you got an easy tow...relax and enjoy!
Nice part is that the trailer isn't a huge brick on wheels...
I used to tow about 3000 lbs, about 400 lbs tongue weight and a 300+lb bike in the bed...On flat ground I set the CC at about 65-67 in 5th got just a hair above 13 mpg....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
