Old 08-02-2009, 03:20 PM   #1 (permalink)
blk04titan's Avatar
problems while towing at incline
I have an 04 titan with a lift on 35s and I was towing around 6500lbs and on the freeway to el mirage my temp gauge kept going up and each time I would go up an incline it would shoot up and then when id go down it would go down but then I went up a hill and temp gauge never went back down, I put trans. coolers and a new radiator, thermostat but it still happens.... what should I do to fix problem and ideas?
blk04titan is offline   Reply With Quote
Old 08-02-2009, 06:54 PM   #2 (permalink)
loufish's Avatar
Re: problems while towing at incline
You didn't state if you had the lower tow or off-road gears...Why do so many guys do that....
You also didn't state if you were towing in 5th or 4th gear...
Sounds like you were running the 14 freeway...or the 15.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 08-02-2009, 08:16 PM   #3 (permalink)
blk04titan's Avatar
have tow package and was in 4th didnt go over 60
Old 08-02-2009, 09:05 PM   #4 (permalink)
loufish's Avatar
Did the converter lock up, or were you in 4th with an unlocked converter?
Did you try to manually grab 3rd gear?
Most of the trans heat can come from the converter not locking up...and it's very common for the converter to unlock in 4th gear and run like that until the it finally downshifts and grabs 3rd gear...
I had the Tow gears and 35" tires towing a little less then you and the truck had issues locking the converter in 4th gear on inclines and grades...The truck was much happier in 3rd during those times...
Born 9/2004
2002 Honda XR650R
Old 08-02-2009, 10:25 PM   #5 (permalink)
blk04titan's Avatar
I manually put in to 3rd and had same problem, I went back and fourth to see if that was the problem and no difference and then while the temp gauge was going up I put the heat on to try and lessen it but it shot out cold air it was odd, I had it on all the way on hot but it pushed cold air in the cabin.
Old 08-02-2009, 11:11 PM   #6 (permalink)
loufish's Avatar
Sorry, I just realized you meant coolant temp, not trans temp....
Born 9/2004
2002 Honda XR650R
over-heating problems when hauling / towing afailedutopia Titan Towing & Hauling 11 12-28-2007 10:46 PM
Disappointing Hemi towing experience (from towing forum) karlconnell Titan Towing & Hauling 11 12-19-2007 07:48 AM
05 Towing Capacity? Towing to Central Mexico Invictusklt Titan Towing & Hauling 3 08-04-2007 01:36 PM
Any Problems Towing After You Level The Titan SpecWell Titan Performance Modifications 3 10-02-2006 11:14 PM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 02:03 PM
