Old 09-12-2007, 12:04 PM   #31 (permalink)
harland98's Avatar
Re: trailer brakes
Originally Posted by buyouts
New to forum... can't find the plug under dash.. I found one but the wireing harness does not fit it. Wondering if there is another one taped up in harness like manual shows. Any help would be great...
Mine was taped under the dash by the emergency brake. You have to remove one cover and it was up in there a bit. If this does not work post a new thread I'm sure someone will chime in!
harland98 is offline   Reply With Quote
Old 09-12-2007, 01:07 PM   #32 (permalink)
BuckyBadger's Avatar
Re: trailer brakes
Also check these pics in this thread
Brake Cntroller hook up. good luck
2007, 4x4,SE, Radiant Silver, BigTow, Bed Liner, Utilitrack, Utilitrack Bed Divider, Truxedo roll up, N-Fab Step bars,
6 disc changer/MP3, Capt Chairs. Michelin Cross Terrain, Born on Nov 06
FOB tailgate mod, Fog lights, Tailgate open light Mod, hard wire Garmin 7200, Hard wire back up camera Monitor, Wet Okole seat covers
2007 Forest River salem Travel Trailor 27RBLE
BuckyBadger is offline   Reply With Quote
Old 09-12-2007, 02:16 PM   #33 (permalink)
buyouts's Avatar
Re: trailer brakes
Thanks, found it by the e brake..
buyouts is offline   Reply With Quote
Old 10-17-2007, 06:33 PM   #34 (permalink)
Re: trailer brakes
I recently purchased a Prodigy controller for my 2006 Titan, I came with a pigtail that connects the controller to the brake wiring harnes, installation and connection were a breeze!!
maindude is offline   Reply With Quote
Old 03-13-2008, 02:15 PM   #35 (permalink)
Re: trailer brakes
I just bought the Tekonsha P3 and was wondering if you guy's have sugestions on where to mount this controller.
Thanks,
geelo1 is offline   Reply With Quote
Old 03-13-2008, 02:48 PM   #36 (permalink)
TitanTeamRoper's Avatar
Send a message via Yahoo to TitanTeamRoper
Re: trailer brakes
Thanks,
I mounted my prodigy just to the left of the hood release, and it attached to the metal frame under the dash, it in reach just in case I need to my brakes while pulling my trailer. I think most people have mounted theirs by there right knee (above the input for the ECM) just make sure you stay within the angles that is allowed by the controller.
Good luck
2005 Audi A4 2.0 Turbo
2006 LE 4X4 Crew Cab Galaxy Black
Big Tow, OFF-Road, Nav, Sunroof
Current mods
2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
TitanTeamRoper is offline   Reply With Quote
Old 03-14-2008, 12:23 AM   #37 (permalink)
Jerrygfd's Avatar
Re: trailer brakes
Seems the Prodigy was the best controller and recommended by my RV dealer when I bought my new travel trailer this month. I guess I could have installed it myself but had them do it. They installed mine to the right side of my dash board just below the steering wheel. Its easy for me to adjust and mine is set for 5.8 right now but I probably will lower the level. Going just below 25mph after adjust the manual control when first testing it, my trailer still will almost stop my truck. I've only travelled 30 miles since buying my trailer and planning on a lot more travel pretty soon. I am impressed with the Prodigy and will have to do some more exploring with the system, my new EazLift Weigh Distribution Hitch with a Robins Sway bar and of course my new Keystone Hornet Hideout 27B.
trailer-brakes-our-trailer.jpg  trailer-brakes-titan-hideout1.jpg  trailer-brakes-titan-trailer3.jpg
2004 Smoke Color SE 4 X 4 Crewcab, Off Road Package, Popular Pkg, Util Pkg, Big Tow Pkg
Installed after purchase: Westin Platinum Step Rails, Carriage Bolt Billet Grilles Upper and Lower, TruxedoTonneau Lo Pro Cover, Firestone Ride Rite Air Bags part #2355, Icon Rear shocks, Bilstein Heavy Duty Front Shock
(*Notes Nissan Dealer installation),
Stillen Dual Rear Straight Exhaust Part #509547*
K&N 77 Series Polished Alum Air Mod Kit #6012KP*
Trailmaster Front Coil Spring Leveling Kit #NL220*
Prodigy Brake Controller installed by RV Dealer
2008 Keystone Hideout 27B Travel Trailer with Eaz-Lift 1000/14000 WD and Robins Sway Bar.
Radio mods: Kenwood DNX 9140, Kenwoods Rear Camera, CDT CL62 front/rear speakers with a Sundown 100.4 Amp purchased from tech12volts
Jerrygfd is offline   Reply With Quote
Old 03-21-2008, 06:43 PM   #38 (permalink)
Re: trailer brakes
Hey guys I've tried searching past posts on this topic, I have an 04 XE with off road package, and am trying to wire my electronic brake controller that I hooked to the connector that I bought from my dealer. The problem is finding the piggytail located under the dash by the e-brake. Pretty sure I don't have one, looked under my brothers LE and found it right away. Anyhow I saw a post a while back stating that the 04 XE didn't have the prewired plug? Does anyone know this for sure and if this is the case how would one go about wiring it? Any info would be greatly appreciated.
havotec1 is offline   Reply With Quote
Old 03-21-2008, 07:02 PM   #39 (permalink)
Derwud's Avatar
Re: trailer brakes
It's easy... First check to see if you at least have the 4 wires at the rear for tail/turn/brake lights, you should. Then get a couple of circuit breakers (20-30 amp auto reset) and lots of 12 Gauge wire. Run one power wire to the rear of the truck (You can also run it through a relay so it only gets power when the key is on, but get the juice straight from the battery) The other power goes into the cab of the truck for the brake controller. Run a wire out of the cab to the back of the truck for the brake signal wire. and if you want a reverse light tap into the back up light circuit..
E-trailer I think has everything you need in a kit.
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Banks Ram Air, Banks Monster Exhaust, Bully Dog Power Pup, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Live Wire Whips, and Banks Power
Old 04-23-2008, 07:03 PM   #40 (permalink)
Question Re: trailer brakes
Hello,
I just purchased a 2005 Titan & really like it... but it doesn't have the harness that comes when new. I've check with NAPA locally. They offer
"Brakeforce" brake controller but don't have a harness in stock. Any experience with Brakeforce? Comments? Also, when I had my new Ford (04) I had no problem installing trailer brake controller. Any problems with the Titan? Thanks,
Hank
hankroe is offline   Reply With Quote
Old 04-29-2008, 06:44 PM   #41 (permalink)
loufish's Avatar
Re: trailer brakes
The Nissan dealer has the brake controller harness...Makes like Prodigy also have direct plug n play harness's, but not sure if they have one for the Titan yet...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 04-29-2008, 07:00 PM   #42 (permalink)
Derwud's Avatar
Re: trailer brakes
Yes, they have a plug and play for Titan and the Prodigy..
Old 08-11-2008, 09:18 PM   #43 (permalink)
TheTitanKing's Avatar
Re: trailer brakes
I just installed my brake controller and now everytime I start my truck it honks.
TheTitanKing is offline   Reply With Quote
Old 08-30-2008, 03:39 PM   #44 (permalink)
Re: trailer brakes
I'm new to the forum and I want to thank you for your help in advance. Does anyone know what the ohm value should be between pins 1 and 2 on a good accy brake relay for the Titan? I'm getting 86 ohms and am wondering if that's OK or not.
Daboosk is offline   Reply With Quote
Old 09-02-2008, 07:37 PM   #45 (permalink)
Re: trailer brakes
Does anyone have a break down of what models need and don't need a relay?
Craig Brickner
Toy Toe'r = 2007 Titan LE CC 4x4 Galaxy/Grey
Track Toy
Car54 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
