Old 05-12-2009, 01:27 PM   #61 (permalink)
mjw357's Avatar
Re: trailer brakes
Originally Posted by boomn29 View Post
As for the relays, that's the part I'm concerned about. I'm running short on time and don't think I have time to order whatever relays might be needed. The 1 dealership I called didn't know much about anything and referred me to somebody local that sold trailers...
Look in the fuse box under the hood, passenger side, behind the battery, black plastic cover.
If you have relays where I have circled, you are good. Otherwise, go to the closest U-Haul and buy the relay kit. About $25.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
The Following User Says Thank You to mjw357 For This Useful Post:
boomn29 (05-13-2009)
Old 05-12-2009, 01:31 PM   #62 (permalink)
boomn29's Avatar
Send a message via AIM to boomn29
Re: trailer brakes
Attachment 79828
Man, look at that fancy diagram - big thanks! I will check tonight!
Assuming I have the relays (or I get them if I don't), I just need to install my electric brake controller and I'm ready to go?
04 Titan 4x4
DD & Tow vehicle
2009 Racing Blog!
boomn29 is offline   Reply With Quote
Old 05-13-2009, 05:31 AM   #63 (permalink)
jsnbrd's Avatar
Re: trailer brakes
Originally Posted by Quartz View Post
If you already have the 7 pin connector and a hitch chances are you already have the relays.
I didn't have the hitch but everything else minus the relays. Don't understand it but it was listed as having the tow package. U-haul will have your relays. I did install my relays and thought that installing those relays would provide 12VDC. do I need another relay for 12VDC at the hitch? Also after installing the relays I tested all the leads due to my 7-way connector being removed and all but the left turn blinker worked, minus the 12VDC. I spliced the tail light to make for short installation. Anyone know the correct fix for the left blinker not working on the factory installed wires? I'd like to not have to splice any wires.
What is involved in installing a 12VDC relay if necessary to get that at the 7-way? or would it be just as simple to run a new wire from another connection. I don't have any other pre-plugged relays at the relay box.
Anyone? Anyone?
Beuler?
jsnbrd is offline   Reply With Quote
Old 05-13-2009, 06:09 AM   #64 (permalink)
mjw357's Avatar
Re: trailer brakes
12v is only present when the truck is running, you might already know that.
Not sure what year your truck is, need to check for fuses at the BCM.
Old 05-13-2009, 06:39 AM   #65 (permalink)
loufish's Avatar
Re: trailer brakes
As already posted, 12v only with key on, and if that's not working then you could be missing the relay, or blown the fuse...
The BCM probably has the BCM harness TSB performed which adds a small sub-harness containing fuses for left/right and brake....Those fuses are under the lower dash right by the steering column
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 05-13-2009, 08:21 AM   #66 (permalink)
Derwud's Avatar
Re: trailer brakes
Ok, time for another newbie question. I've read up a lot, but want some information on my specific model - 04 Titan XE KingCab 4x4 - non big-tow.
Just bought my Titan last week and picking up an empty 18' car trailer tonight - and towing my car this weekend. My truck has a drop hitch and 7-pin connector already.
I know I need a Ball Mount (2 5/16") and an electric brake controller. Does the EBC plug into the 7-pin harness? Just wanting to verify what I need to buy.
The 04's XE's did not come with a factory tow harness. You may have a custom harness on your truck..
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Banks Ram Air, Banks Monster Exhaust, Bully Dog Power Pup, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Live Wire Whips, and Banks Power
Derwud is online now   Reply With Quote
Old 05-13-2009, 08:31 AM   #67 (permalink)
boomn29's Avatar
Re: trailer brakes
Attachment 79828
Thanks, I did not have the relays!
Picked up the trailer last night. I needed the 7-pin adaptor from Autozone and the relays under the hood for the running lights to work.
Since it was empty, I didn't worry about the electric brakes. I did get the Prodigy controller and will install that tonight.
It's an 18' Aluminum ATC Trailer that I will use to pull my 06 Mitsubishi Evolution to the track. Should be towing with it this weekend!
04 Titan 4x4
DD & Tow vehicle
2009 Racing Blog!
Old 07-23-2009, 11:34 AM   #68 (permalink)
Blevinger's Avatar
Re: trailer brakes
Just wired up my Prodigy controller last night. What a snap! Wuz stupid easy.
Ordered it off Amazon WITH Nissan factory hookup for around $115. Already had the wiring in the glovebox but didn't need Nissan's version because the Prodigy hookups had the Nissan plug on one end and the brake controller on the other. No splicing!
Im in an '05 CC LE so mounting options were a little tight (can't use center area). Chose to stick it just above the parking brake; figure that's about as out-of-the-way as it gets.
Drill, drill, click, click—done. 20 minutes tops only because I was thorough in reading the directions over and over.
Blevinger is offline   Reply With Quote
Old 07-23-2009, 08:01 PM   #69 (permalink)
HRTKD's Avatar
Re: trailer brakes
Blevinger, if you're left handed that's a great spot to put the controller. I'm a righty so I mounted mine directly below the steering wheel using the same metal beam under the dashboard that you did.
Jim
Old 08-06-2009, 01:14 PM   #70 (permalink)
Re: trailer brakes
i was wondering if any body can tell me if if the brown relay in the top left corner (in the image above. the one that does not have the red box drawn around it) has any thing to do with the trailer lights. i bought the two other relays and noticed i didnt have that one. i have not tested it yet with out it, do i need that realy for the trailer lights or not?
Any help would be much appreciated.
mattlbrcht is offline   Reply With Quote
Old 08-22-2009, 06:27 AM   #71 (permalink)
Re: trailer brakes
I have a leer top on my '04 CC 4X4 w/ big tow. I am thinking about hooking up camper top's third brake light and dome light to the truck side trailer wires. Any thoughts?
jumpy is offline   Reply With Quote
Old 08-22-2009, 10:44 AM   #72 (permalink)
HRTKD's Avatar
Re: trailer brakes
The Leer installer didn't already do that for you? Mine did. There are a couple of fuses that they added. As near as I can tell the power for the topper third brake light is coming through the brake light assembly (driver side) while the power for the dome light is a totally separate wire ran all the way from the battery.
If you take power off the trailer hookup then your dome light will only work when the ignition is on.
Jim
Old 08-24-2009, 05:35 PM   #73 (permalink)
chad734's Avatar
Re: trailer brakes
I have an 06 SE off road with the big tow and when installing my brake controller I hooked up the adapter to the factory pigtail with the key off. I hit the brake pedal with the wires while trying to route them and they sparked. I figured I blew a fuse. When I hooked up the brake controller it didn't work. When I checked the red wire from the pigtail it was dead. I looked in this thread and found the wiring diagram and was able to find the blown fuse. The diagram states it is a "fusable link" but what I found when trying to replace the blown fuse is that it is a "Dealer only part" $15.99 and had to order(of course!!) I guess what I am trying to say is I have power to my brake controler and it is wired up to the factory pigtail. When I push the manual lever to the left my brake controler red light comes on and I have power going to the 7pin connector at the bumper. I just want to share my experience to help other TITAN owners. I was frustrated not being able to find the correct fuse. By the way it is it he rear fuse box on the engines right(passenger side) look at the inside of the cover for the diagram. It is labeled "Electric brake controller" It really stinks to replace this fuse because it also runs the radiator fan and ignition switch. This fuse is three in one. I needed mine to pull my 3 horse goose nect trailer so I soldered it back together in a pinch( ordered a new one today) Hope this helps someone else!!!
chad734 is offline   Reply With Quote
Old 10-03-2009, 09:57 PM   #74 (permalink)
LAE
LAE's Avatar
Re: trailer brakes
Just wired a brake controller, Odyssey proportional unit. Spent a lot of time looking for the OE connector - located up above the E brake pedal, close to the dash - burried, white connector. 2008 Titan.
LAE is offline   Reply With Quote
Old 10-14-2009, 12:31 PM   #75 (permalink)
Re: trailer brakes
Thanks Derwud useful info
NISSAN09 is offline   Reply With Quote
