Old 08-15-2009, 06:07 PM   #1 (permalink)
tbritt's Avatar
Want a bigger travel trailer
Well guys I know this has been asked before but after 46 days and 7200 miles and 8 states, I want something different. My 21ft Keystone Lite is great but we want something Bigger maybe a slide or two, maybe 28ft, we met tons of people and seen some nice rigs. What you see is what I got no more up grades, it's got BT package and brake controler. Any ideas out there for what I could be looking at. I know there alot of good ideas out there so let me know what you think..... Thanks
07 KC 4X4 SE "RED BRAWN"
MOD's
ION wheels 10x18
Chrome wheelwell trim
Chrome Door handles
Chrome Tube step rails
Dual in/out Magaflow
Painted Calipers..more to come I'm sure
Spray-in bed liner
"Beers cheaper than Gas"
"DRINK DON'T DRIVE"
tbritt
tbritt is offline   Reply With Quote
Old 08-16-2009, 10:48 AM   #2 (permalink)
4wheelwhore's Avatar
Re: Want a bigger travel trailer
i got a jayco 26bh works well and seems to be the perfest driveability length
4wheelwhore is offline   Reply With Quote
Old 08-16-2009, 11:48 AM   #3 (permalink)
loufish's Avatar
I would (and plan to) stay under about 27-28 ft overall length...I also plan on staying under 7,000 lbs loaded ready to go....
This alows me to still tow quite a bit for a 1/2 ton truck while at the same time I'm not running the truck at 100%
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 08-16-2009, 12:33 PM   #4 (permalink)
I think Loufish has good advice... I tow a 29ft 4in trailer including the tongue and I dont think I would want any more length. Dry weight about 6400# when its all loaded up and have dirt bikes in truck its pushin 8000-8500. I wouldnt want to pull much more weight. can drive 70 75 mph but much faster and it will get some sway. If your looking for a bigger trailer I would also recommend airbags.
mxracer450 is offline   Reply With Quote
Old 08-16-2009, 01:10 PM   #5 (permalink)
Shane06fl's Avatar
30ft over all lenght (includes tongue) which means you get about a 27ft box and a GVWR at 7500 or less is pretty much ideal for these trucks IMO. Your at the 85% rule of thumb load and with a properly set up hitch you will have pleasant tow.
I have a Keystone 24ft RS. The closed box is 24ft with a rear slide that adds 6 more feet. The front has double set of bunks. This fits my family of 4 and dog just right. Side slides are great if plan on spending time in the TT. We don't, the only time we are inside is at bedtime or if a storm pops up. The GVWR is 7500lb and Loaded down I am 700lbs shy of that and it tows great.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
Old 08-16-2009, 03:58 PM   #6 (permalink)
loufish's Avatar
Here's the trailer I really want. And the spec's should equal a pleasurable towing experience...
http://www.forestriverinc.com/nd/def...series=7WideTT
Nice size, roomy bathroom and with the slide it gives the living area lot's of room...
Born 9/2004
2002 Honda XR650R
Old 08-16-2009, 04:32 PM   #7 (permalink)
Shane06fl's Avatar
^^ I like that!! Neat idea with the Murphy bed upfront.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
Old 08-16-2009, 04:35 PM   #8 (permalink)
Shane06fl's Avatar
I like this one even better. More sleeping space with not much extra weight
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
Old 08-16-2009, 04:58 PM   #9 (permalink)
LJRome's Avatar
Those are both nice floorplans. I tow a 7500 lb. 32 ft fiver and I have absolutely no trouble with my 2009 KC with tow package. In fact, I often forget it is there because it tows so well and the truck handles it so well. My trailer has an 18 ft. superslide that gives us plent of room with the sofa and dinette in the slide. I have a front bedroom in the section above the truck bed. I have had up to a 35 ft. bumper pull and would never go back from the fiver. With the KC, the fiver is not that big of a deal and the tow package gives you plenty of capacity for towing. There are some awesome light weight fivers on the market with low pin weights that the T can handle very well. This is just my opinion, of course, but I think that the fiver actually works the truck less because of the connection being over the axle and there is no sway. I recommend to all of my friends that when they replace their travel trailer they should go with the fiver and a couple have. They said it was the best move they ever made. Again, this is just my opinion, but you have enough towing capacity for the fiver if you find a nice, light weight unit and they provide a ton of storage under the bathroom that is usually pass thru to get more of the junk (or at least that is what I call all of the extra things that we take such as chairs, table for outside, camp stove, etc) out of the interior. Good luck on your search and let us know what you do.
2009 Nissan Titan XE - Majestic Blue
Still relatively stock but I am working on it.
Added So Far:
Fog Lights, SilverStars (High, Low, and Fog Bulbs), Power Door Locks with Keyless Entry, Airbags, Running Boards, Mesh Grill
She's a work in progress!
LJRome is offline   Reply With Quote
Old 08-16-2009, 05:36 PM   #10 (permalink)
tbritt's Avatar
Thanks guys for all the input and I really like the floor plans sent....gonna look them up, will let you know what I end up with..
MOD's
ION wheels 10x18
Chrome Door handles
Spray-in bed liner
"DRINK DON'T DRIVE"
tbritt
Old 08-16-2009, 07:32 PM   #11 (permalink)
This past spring we upgraded from a 25 ft (~4500 lb) TT to a 32 ft (~6300 LB) TT with double slides (K-Z Spree 318BHS). The extra length hasn't been an issue, except remembering how long it is when turning. The trailer handles about the same as our old 25 footer. I haven't noticed any significant difference in wind or with passing trucks. The real key is to have a good weight distribution and sway control set up. The long wheelbase on my Titan probably helps as well.
Weight-wise, I wouldn't want to tow much more with my Titan. We're at about 6800-7000 lbs loaded up. The GVWR is 7500 lbs. Just about any hill will drop you to 3rd gear. I really wouldn't want to tow into a 20+ MPH headwind.
Good luck trailer hunting.
2008 Titan SE, Crew Cab, 4x4, Long Bed
Popular Pkg w/ Captains Chairs
Utility Bed Pkg, Big Tow
Smoke/Charcoal
Roadmaster Active Suspension, Westin Sure-Grip Aluminum Running Boards, Leer 100R Cap, Lund Bug Shield
Exocet is offline   Reply With Quote
Old 08-22-2009, 07:23 PM   #12 (permalink)
I pull a 34 ft Keystone VR-1 with a 2008 BT quad cab. It pulls it like a champ! My temps are all very low, even when going up 8% grades in NM. However, I am cautious and stay around 60mph when towing. Empty wt of the trailer is 7,000lbs. The most I've had loaded is around 9,200 lbs.
scubaman1 is offline   Reply With Quote
Old 08-22-2009, 07:52 PM   #13 (permalink)
Pops's Avatar
I've been pulling a 30' Jayco 29BHS a little bit this year and it handles great!! It's the hitch weight that you need to watch the most.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 08-23-2009, 12:02 PM   #14 (permalink)
Just sold a Dodge 4.7l and purchased an 07' T-CC w/Tow Package and more with the intension of towing a 26'-30' TT with weight's between 7300-8400lbs GVWR. I have narrowed the selection down to several makes and models. My wifes only requirement is countertop space......very challenging. Any suggestions would be appreciated. Thanks.
2007 Titan SE Crew, Tow pkg, Popular pkg and Hard Tonneau Cover
kjstanger is offline   Reply With Quote
Old 08-23-2009, 05:07 PM   #15 (permalink)
Pops's Avatar
Originally Posted by kjstanger View Post
.... My wifes only requirement is countertop space......very challenging. Any suggestions would be appreciated. Thanks.
Fifth Wheels, Toy Haulers & Travel Trailers - Heartland RV
2005 Armada LE 4x4
New Travel Trailer Pops Titan Pictures & Media Post 14 04-28-2009 08:19 AM
Questions on new Travel Trailer Ramon Titan Towing & Hauling 5 06-24-2006 08:38 PM
Anyone ever lift their travel trailer? CoachBoone Titan Towing & Hauling 16 06-05-2006 01:59 PM
Travel Trailer towing + ? Tom-ADC Titan Towing & Hauling 21 08-20-2004 11:02 PM
Need Travel Trailer Advice.... JetTech Off-Topic Discussion 6 05-23-2004 11:40 PM
