Timbren owners, I have a quick question for you!!!
I noticed my Timbrens are loose on the mounting pad. I tighten them down pretty good, but there is @ 1/8" gap or play between the rubber and the base plate. It appears the bolt acts like it has bottomed out, even though it has only gone @ 95% thru the thread part of the base plate. Is this normal??
Thanks!
2006 SE, CC, Big Tow, white
Born 5/06
Re: Timbren owners, I have a quick question for you!!!
The ones on my Fronty are tight. Did you get the washers in the right spot?
TrainingWheelsWhore™
08 Pro 4X RED ALERT SWB Crew cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a Clipper 1465HST Trail ready pop up. Grumpy Old Man Club http://s3.bite-fight.us/c.php?uid=214743
The instruction don't even show the washer. Since it was inside the Timbren hollow area, I figured that is where it should go. Even if it was on the bottom it would not make a difference, it would still be loose. I guess I will have to call them. I cranked down on them pretty good, and the thread would not go thru the very last part of the base plate. Thus, leaving it a little loose, which can't be good with all the axle movement.
Born 5/06
Nah, something isn't right. I bolted mine up and cranked down on them to get the bolt good and tight...
Good deal! You'll love those things!
took a couple of pictures with the tire off. It was easier to tighten it down to base plate with the tire off. I jacked the truck up by the frame on one side, hence the big space to work with.
Born 5/06
You hook up the trailer yet?
not yet
My Tongue weight is 700 lbs, so when I put the Generator in the bed and load up 4 passengers I am about 500 lbs over my max payload. The Timbrens should take care of that. Normally, it is just the two of us and I am ok. I was looking for some help on those few heavy trips and this should work.
I'll report back in a few weeks when I get to pull the travel trailer again.
Born 5/06
Have you tried out the Timbrens yet?
Finally, got to tow my travel trailer with my Timbrens installed.
I filled up the water tank so I would have my max tongue weight of just under 800 lbs. The ride with the load was firmer, like a 3/4 ton truck, but not harsh. The truck doesn't squat as much and it seems more stable in the rear.
So far so good, will put more miles this weekend.
Born 5/06
You could get the spacers if you want it to sit higher in the rear...I sure liked mine!
