Re: Towing a tent trailer
My tent trailer towed sooo sweet back there....Mine had a lot of tongue weight and the axle was mounted farther back then most...
I'd use the T/M but that was for around the city. Mine weighed almost 3000 lbs loaded but 5th gear was used all the time on flat ground...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
