Old 09-03-2009, 07:12 PM   #1 (permalink)
Firestone Air Bag Compressor Installation Help
Hi all.
I've just purchased my second Titan and I want to put the Firestone compressor on the truck in conjunction with the Firestone air bags. I had the air bags on my other Titan - no problem installing them. But where are you folks installing the compressor? The engine compartment is out. No room there. I think that the air gauge and switch can be mounted in place of the drink holder at the bottom of the center dash, but how did you route the air lines? What did you hook the power too?
Any and ALL details would be greatly appreciated.
Many thanks!
MDBrown is offline   Reply With Quote
Old 09-03-2009, 07:44 PM   #2 (permalink)
helomech's Avatar
Re: Firestone Air Bag Compressor Installation Help
I put mine inside the enclosure of my AEM intake.
I came into this world naked, screaming and covered in someone else's blood I plan on leaving this world the same way.
Old 09-04-2009, 12:07 AM   #3 (permalink)
Nissanloyalist's Avatar
I mounted mine under the rear seat and wired it to he amp wires behind my seat. I mounted the controller under the dash below the steering wheel and this worked pretty well for me. Then I only had to put one hose through the firewall.
Gone but will not be forgoten! 04 CC SE Smoke 4x4 DVD OR BT. AEM Brute Force CAI, Magnaflow Muffler, Fitch Fuel Catalyst, Firestone Airbags, Mag-Hytech Diff cover, Stillen front & rear sway bar. Scangauge II. Superchips Cortex Programmer. Stainless rocker panels. Pull-Rite 12k and Prodigy controller for the 2007 Cougar 278RKS. Amsoil throughout!
New ride: 2009 GMC 2500 HD LMM D/A SLT CC 4x4. Line-x, dual headrest DVD, OEM step rails and mud guards, Mag-Hytec diff cover.
Nissanloyalist is offline   Reply With Quote
Old 09-04-2009, 01:13 AM   #4 (permalink)
Sftail1990's Avatar
How big is that compressor? I will be doing these in the future and I was thinking behind the tailight on the other side from where my axle vent hose is. There seems to be a bit of room there, just would like to know if it might fit.
2006 Titan SE CC Granite, S&B Intake w/ AirRaid TBS, Superchips Cortex, Big Tow w/ 18" Chrome Six Spokes, Active Tuning Grounding Kit, Axle Vent Mod, Mag-Hytec rear diff cover ,True Trac, Armada front spoiler,and Cowl painted. Nismo stripe kit. Katzkins leather interior. Stillen Dual Side Exit Exhaust, Stillen front sway bar w/PRG end links. PRG mini lift, Bilstein 5100's, PML trans pan w/guage set in Lo-tek pod. All Amsoil fluids, of course, I am a dealer. Not one piece of WRP Technology junk on it.
Sftail1990 is offline   Reply With Quote
Old 09-04-2009, 04:42 AM   #5 (permalink)
The compressor is too large to fit there. You will need more space.
Old 09-06-2009, 05:35 PM   #6 (permalink)
All good ideas so far. Many many thanks!!
Old 10-10-2009, 08:01 AM   #7 (permalink)
Its rather simple to find and installation spot for an air compressor, but there are a few do's and donts. Its really just running the wires and lines that can be tedious and time consuming. I read one, or a few posts about installing it in the engine bay. I would recommend against that although its not always harmful. The reason is that if you use the compressor often, it heats up like anything else, and the engine bay is already hot. This poses a possibility of an over heated compressor and a shorter life span. Like i said, its not an absolute no-no, but there are safer spots. And if you invested in an Firestone on-board air compressor, its probably because you're going to use it often. Trucks that need helper springs, air bags or suspension help dont need a failure in the middle of work day.
I seen a post for under the seat, thats probably a better suggestion and its where i put mine. You can avoid air ducts from blowing on by turning the fans on and following the current. Again, heat (winter climate guys only) can be an enemy to electric motors.
Additionally, I would check out the specs in the Firestone manual, plus try reading the recent reviews also found at the same site
tim514@gmail.com is offline   Reply With Quote
Installed an air compressor today chrisr400cc Titan General Discussion 4 11-10-2009 05:38 PM
FS: Firestone Air Bag Helper Spring mlvanhook Buy/Sell 5 10-10-2009 08:40 AM
air compressor helomech Titan General Discussion 8 07-03-2007 09:29 PM
Hide Air Bag Compressor deebie47 Titan Towing & Hauling 4 06-12-2007 06:40 PM
Air Tools and Compressor Khamburg Off-Topic Discussion 9 02-26-2005 06:45 AM
