Old 09-10-2009, 12:15 PM   #1 (permalink)
Creaking and groaning from front end
Hooked up my TT to my Titan yesterday and took it to a local CG to hook up and check out the systems. I've towed this trailer with this tv 6 or 7 times and am well within the weight limits on total and tongue weight. When I was making turns I got some fairly loud groans and creaks from the front end. Haven't had this before and I'm wondering if I had the WD bars mis-adjusted. Could that cause the creaks and groans?
dd992emo is offline   Reply With Quote
Old 09-17-2009, 05:51 PM   #2 (permalink)
Shane06fl's Avatar
Re: Creaking and groaning from front end
are you sure it's the front end?
Do you use a friction sway control? They will groan on turns.
Grease the ball and trunnion bar pivot points.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
Old 09-17-2009, 08:36 PM   #3 (permalink)
hoojs12840's Avatar
Like he said grease the Ball and the WD bars pivot points. Mine did the same thing
hoojs12840 is offline   Reply With Quote
Need help with creaking and popping from my front end GR8WHITE Titan Suspension 26 03-25-2009 09:50 AM
Grinding and groaning noise? all torque Titan General Discussion 22 12-07-2008 05:34 PM
WTT chrome front end for black front end billaj Buy/Sell 3 06-21-2008 09:07 PM
Front end vibrations still after full front brake replacement. please help trevalockess Titan Problems & Dealer Service 0 11-02-2007 10:15 PM
Front End Creaking TheFlash Titan General Discussion 1 02-26-2007 12:13 AM
