Old 09-27-2009, 10:54 AM   #1 (permalink)
Brake Controller Help
Hello, I Have a Hayes Lemmer 'Syncronizer' brake controller with 4 wires out the back. Red, Black, white, and Blue.
I was looking at the Titan's harness, and there are 5 wires, Red, Black, Brown/white, and Red/blue, and Red/green.
Which one's do I splice together to make my wiring harness work?
Thanks.
Joe B.
Purchased 03-29-08
Searched for a Truck for a year, almost bought several before....
Red Brawn 08.5 Nissan Titan
No Mod's yet
It's the best truck ever!!!!
Joe B.
I'll keep my guns; you keep the 'Change.'
fpd7 is offline   Reply With Quote
Old 09-27-2009, 11:00 AM   #2 (permalink)
mjw357's Avatar
Re: Brake Controller Help
Try reading page 1 of this thread, about halfway down there is a word document that has the Nissan color codes for the brake controller harness. Note that the illumination wire is not typically used.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 09-27-2009, 11:11 AM   #3 (permalink)
thanks so much!
Purchased 03-29-08
No Mod's yet
Joe B.
Old 09-27-2009, 03:38 PM   #4 (permalink)
Well, I got the controller hooked up correctly, but the trailer seemed kind of heavy. I pulled onto the scale, and the trailer axles alone were 10,800 lbs., and I don't know how much the tongue weight was. The trailer was loaded heavy on the front, so it wasn't balanced. Total weight was 18,100, with 4400 on the trucks rear axle. I told my friend it was too heavy to pull without a WD hitch, so we got a 2500 Dodge to pull it. That worked fine, but he didn't have trailer brakes, and slid through a few intersections on the gravel roads. Made for an interesting trip.
Purchased 03-29-08
No Mod's yet
Joe B.
Old 09-27-2009, 04:44 PM   #5 (permalink)
Carbeaux's Avatar
That's too heavy to pull with a Titan WITH the weight distributing hitch. If you figure your truck weighs in at let's just say 5500 lbs, subtract that from the total weight you measured, that trailer was 12,600 lbs. Just too much trailer for a 1/2 ton truck.
Hook 'Em Horns!
Carbeaux is online now   Reply With Quote
Old 09-27-2009, 05:58 PM   #6 (permalink)
Originally Posted by Carbeaux View Post
That's too heavy to pull with a Titan WITH the weight distributing hitch. .
Yeah I know, but I was trying to save some face with my WD comment. The 2500 looked much better pulling it, but was nearly a disaster with no trailer brakes. It wasn't my trailer, or my stuff. I just ended up following along in case there was trouble, I could give a ride to the guys back to town.
Purchased 03-29-08
No Mod's yet
Joe B.
Do I need a brake controller? Crappie Master Titan Towing & Hauling 11 04-15-2009 09:04 PM
brake controller help Danny's08TitanCC4x4 Titan Towing & Hauling 8 09-11-2008 05:00 PM
Brake Controller joeandmaria Titan Towing & Hauling 28 02-06-2006 06:39 AM
New Brake Controller Mike Up Titan Towing & Hauling 5 10-17-2005 09:31 PM
