Old 09-29-2009, 02:07 AM   #1 (permalink)
Need help with towing.
Hey guys as some of you may have seen my truck on the other posts its pretty big, I have something to ask, Im running a 17' lift on 40' tires how do you think my towing will be? Im going to pull a zieman 8x10 flat bed trailer with a rhino loaded on to it. Im wanting to know if my tires and lift will have a huge impact on my towing smoothnies of the ride swirvie etc? Any help would be greatly appreciated.
Thank You
felix55 is offline   Reply With Quote
Old 09-29-2009, 06:43 AM   #2 (permalink)
loufish's Avatar
Re: Need help with towing.
so how's the perfomance now?.....
Tow in 3rd gear, if you have the tow gears at 60 mph you should be running about 2600 rpm...
You just had to have the tallest truck....too late now to worry about if it will actually perform....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 09-29-2009, 10:27 AM   #3 (permalink)
Yea I guess I had to try and make my truck as tall as possible, and then think about towing.
My biggest worrie was,will the truck and trailer not be staible on the road? I just thought if the truck is so big I might have the trailer going side to side? Should I do airbags? Also I see your in Burbank,hit me up sometime for a pismo or glamis trip. Will caravan together I havent been to either place in over 6 months.
Old 09-29-2009, 05:35 PM   #4 (permalink)
Come on guys 109 views and only 2 reply ???? Come on TitanTalkers help me out.
Old 09-29-2009, 05:55 PM   #5 (permalink)
kevlar's Avatar
I'm pretty sure those 40" tires are going to be a nightmare. The sidewall flex is going to have you fishtailing all over the place. Airbags won't fix that. I have no idea how heavy the load your talking about, but if it's more than 4000, I bet your in for a-hell-of-a-ride.
kevlar is offline   Reply With Quote
Old 09-29-2009, 06:04 PM   #6 (permalink)
4mula1fan's Avatar
You just don't see bigass lifted trucks towing....
TrainingWheelsWhore™
08 Pro 4X RED ALERT SWB Crew cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a Clipper 1465HST Trail ready pop up.
Grumpy Old Man Club
http://s3.bite-fight.us/c.php?uid=214743
4mula1fan is online now   Reply With Quote
Old 09-29-2009, 07:01 PM   #7 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
you will be fine. just get a pretty big drop hitch. i had 38.5's on and pulled a 16ft flatbed with a 5800-6000lb john deere tractor on. the rhino weighs about 12-1700lbs. you will be fine. try and find a 10-12" drop. i have a 6x10ft trailer i pull my honda rincon with and i have had it up to about 85 or so and no issues at all on my 37 boggers.
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
Old 09-29-2009, 08:02 PM   #8 (permalink)
RckyMtnTitan's Avatar
Send a message via AIM to RckyMtnTitan
Airbags probably won't help your towing performance a great deal but will help with droop if anything.
"The Panda"
04' SE White- purchased June 04
Big Tow, Offroad 4x4, ProComp 6" Lift, SAW's in front, Helo Maxx6 18's on ProComp 35' Xtreme AT's, 6000K HID low beams, Billet Grille, Bushwacker Fender Flares, XE Mirrors and Door Handles, Black Painted Badges, Brushed Aluminum Dash and Trims, Titanium Gauge Face, Pin Stripes, "Endurance" Windshield Decal, Hood Decals, "Van Halen" Engine Cover, Air horn.
Power: Helix Throttle Body Spacer, Magnaflow Exhaust, AEM Brute Force Intake, 2* Timing Advance
Audio: Alpine PDX1.600 Amp, Tech12 sub enclosure, 2 10" Boston G1s.
RckyMtnTitan is offline   Reply With Quote
Old 09-29-2009, 09:40 PM   #9 (permalink)
loufish's Avatar
You didn't mention how much weight...Get the tires aired up and do a weekend test tow...
Born 9/2004
2002 Honda XR650R
Old 09-29-2009, 10:17 PM   #10 (permalink)
rtc1184's Avatar
the rhino and the trailer maybe 2200-2500lb
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
Old 09-29-2009, 11:19 PM   #11 (permalink)
Yea I would probably say around the 2500-3000 range. Im just worried about the sway.
Old 09-29-2009, 11:20 PM   #12 (permalink)
Well it should not have much of a drop with towing 3000 pounds. There is no point of getting airbags?
Old 09-29-2009, 11:22 PM   #13 (permalink)
So you believe if I get a correct size drop down hitch and level the trailer out completely straight I should be fine with having no sway?
Old 09-29-2009, 11:23 PM   #14 (permalink)
Thats all Im worried about, I hate having to fishtail and to be totally honest it just freaks me out on the road and ruins my whole trip.
Old 09-29-2009, 11:25 PM   #15 (permalink)
I have seen some big *** chevys and fords pulling 25 ft toy boxes with the front fully up and the rear drooping.
a towing question and a towing break question disastergrafix Titan Towing & Hauling 12 08-19-2008 08:25 AM
Disappointing Hemi towing experience (from towing forum) karlconnell Titan Towing & Hauling 11 12-19-2007 07:48 AM
05 Towing Capacity? Towing to Central Mexico Invictusklt Titan Towing & Hauling 3 08-04-2007 01:36 PM
9600 lbs towing! try 17000 lbs towing standingtall Titan Towing & Hauling 1 12-08-2005 05:48 AM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 02:03 PM
