Old 10-09-2009, 03:53 PM   #1 (permalink)
4wheelwhore's Avatar
Which Setting on Cortex For Towing
Just trying to get more input from you guys on which setting you use on your Cortex while towing? From what I saw there is no mention if the 87 tune is safe to tow with or not--Thanks Much
4wheelwhore is offline   Reply With Quote
Old 10-11-2009, 06:18 AM   #2 (permalink)
loufish's Avatar
Re: Which Setting on Cortex For Towing
I'm extremely wealthy so I run 91 oct fuel....
Ok...not so wealthy, but I do run 91 for the most power to which I've become addicted to...so I run the 91 oct Tow Tune...tows great!
Don't have any other info for you...sorry...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 10-11-2009, 06:50 AM   #3 (permalink)
If I am towing local I don't bother to switch the tune from 87 to the tow. If I am going to haul a distance then I will switch to the tow tune. It's shift pionts seem to be better with the tow tune. I am hauling 4,000 to 6,000lbs.
FTMS is offline   Reply With Quote
Old 10-11-2009, 04:24 PM   #4 (permalink)
hey guys, thanks for the input, I think I will try the 91 tow tune--Thing is I get 87 for free so a little more expensive then just the differance between.
Old 10-11-2009, 05:45 PM   #5 (permalink)
The last time I used the tow tune I ran 87. Never heard any spark knock or anything.
Old 10-12-2009, 09:20 AM   #6 (permalink)
I guess a little experimenting will take place -- on the other hand boy is my thottle touchy now!!
Old 10-12-2009, 09:46 AM   #7 (permalink)
Pops's Avatar
I usually use the Light Tow tune except for trips to/from storage and haven't noticed a difference between 87 or 91 oct so I just usually run 87.
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 10-12-2009, 10:08 AM   #8 (permalink)
Juday's Avatar
Light Tow? On my Cortex I have the following options:
87 Mileage XS
87 Performance Tune
91 Tow Tune
91 Performance Tune
Where are you getting all of these other options?....
35x12.5x17 Cooper Discoverer STTs
AEM Brute Force CAI
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
PowerSlot Cryo Rotors w/ Hawk LTS pads from Frozen Rotors
Superchips Cortex
Old 10-12-2009, 10:28 AM   #9 (permalink)
Pops's Avatar
"Light Tow" is the same as the Tow Tune. Maybe it depends on which update you're on, I haven't updated in awhile.
2005 Armada LE 4x4
Old 10-12-2009, 08:54 PM   #10 (permalink)
loufish's Avatar
Oh yeah....40 mph comes up pretty quick for a truck...
Born 9/2004
2002 Honda XR650R
Is Nissan setting themselves up for a lawsuit? Smoke05 Titan Problems & Dealer Service 67 01-17-2009 08:46 AM
G-Tech Pitch Setting?? PAPARYNO Titan General Discussion 1 01-07-2008 08:15 AM
Cipher setting question roy365 Titan Performance Modifications 24 10-09-2007 08:21 PM
Setting for a race need help. 1BadTitan Titan General Discussion 62 11-30-2005 06:54 PM
Setting the clock??? sundancekid Titan FAQ & Howto Area 8 08-25-2004 08:35 PM
