Old 10-12-2009, 01:14 PM   #1 (permalink)
rizzo1317's Avatar
2008 Titan King Cab LWB
Have a 2008 Titan XE King Cab LWB with BT 18" alloy wheels. I'm looking at purchasing a 2009 Komfort 283T travel trailer. The dry weight on the trailer is 7353 lbs, tongue weight 1,023 lbs and the length is 30'. My question is can my truck safely tow the trailer after I install firestone air bags, sway bar and prodigy trailer brake system. The more info the better thanks. Frank
rizzo1317 is offline   Reply With Quote
Old 10-12-2009, 07:16 PM   #2 (permalink)
Re: 2008 Titan King Cab LWB
The tongue weight would be my main concern. You're already over the 1000 lb tongue weight that the Class IV receiver is rated for. When the trailer is loaded, that tongue weight will probably be over 1200 lbs. If those are "brochure" weights, the actual weights are probably even higher than you listed.
My TT weighs in at about 6300 lbs empty (GVWR 7500 lbs). Personally, I wouldn't want to pull around much more weight with the Titan.
2008 Titan SE, Crew Cab, 4x4, Long Bed
Popular Pkg w/ Captains Chairs
Utility Bed Pkg, Big Tow
Smoke/Charcoal
Roadmaster Active Suspension, Westin Sure-Grip Aluminum Running Boards, Leer 100R Cap, Lund Bug Shield
Exocet is offline   Reply With Quote
Old 10-13-2009, 05:22 PM   #3 (permalink)
rizzo1317's Avatar
Thanks for the reply thanks good advice. Frank
2008 4x4 king cab for sale jd5051 Buy/Sell 1 05-05-2009 09:26 AM
2008.5 Nissan Titan SE 4x4 King Cab-6" Lift heyitischris Buy/Sell 0 03-21-2009 01:34 PM
2008 Titan King Cab LE LWB in NJ - 22,995.00 luzzy Buy/Sell 13 01-15-2009 05:50 PM
2008.5 King Cab amp question Major Titan Visual & Audio Discussion 2 05-03-2008 03:16 AM
BakFlip® Tonneau Cover for 2008 Nissan Titan King cab bennyb2 Buy/Sell 7 04-11-2008 04:41 PM
