Old 11-04-2009, 07:53 PM   #1 (permalink)
Looking to install Amp
Let me just start by saying this, car audio really confuses the crap out of me.
Here is what I have:
Kenwood Excelon Receiver with front and rear amp pre-outs
Infinity 2-ohm tweeters in the dash
Infinity 2 -ohm 6x9's in the front door
Infinity 2 - ohm 6 1/2" 2 ways in the rear door.
My issue: I am thinking about installing an amp to get just a little bit better sound from the speakers, however, I am somewhat a novice at this.
Would there be a good sub $100 amp to do this? I am not an audiophile, and the music would not be cranked all of the time.
Next, could I wire a 4 channel amp into this set up somehow? Run the 6x9's and the tweeters in parallel or in series off of the front channel, and the 6 1/2's off of the rear channel? Would that fry a cheaper amp?
I was considering getting some components but I am on a budget and do not want to really lay down the cash now.
Just looking for suggestions, sorry if I sound like such a noob.
Thanks,
Zack
06 KC 4X4 Off-Road Big Tow
Nismo CAI and Exhaust
2" NCD levelling kit
1-1/2" rear blocks
Bilstein HD's front
Bilstein 5125's rear
Infinity Sound
www.iamstruth.com
zkeys is offline   Reply With Quote
Old 11-05-2009, 05:32 AM   #2 (permalink)
Reply:
Hey that is a great setup you have .Id suggest you see pioneer stuff as well .
Dentist in Minneapolis
markakleive is offline   Reply With Quote
Old 11-05-2009, 06:33 AM   #3 (permalink)
MacOtac's Avatar
Send a message via MSN to MacOtac Send a message via Yahoo to MacOtac
Re: Looking to install Amp
I am doing the same thing... All new door speakers and head unit. I am going to use a ALPINE MRP-F300 4 CHANNEL AMPLIFIER to run my door speakers. You just need to make sure your After market Head unit has Pre Amp outlets. IF it does you just connect the amp to it. If not you will ne to buy a LOC to connect the 2. They have that Amp for sale on ebay for 138$ with free shipping.
Here is the link: BRAND NEW 2009 ALPINE MRP-F300 4 CHANNEL AMPLIFIER!!! - eBay (item 270462642752 end time Nov-27-09 09:27:06 PST)
Sig: By dOva
"Green Machine"
2005 SE CC 2WD Canteen Green
MacOtac is online now   Reply With Quote
Old 11-05-2009, 07:17 AM   #4 (permalink)
I just won this for pretty cheap. I am going to give it a try.
SONY! XPLOD XM-554Z XM554Z ~ 600W ~ 4 CH CAR AMPLIFIER! - eBay (item 270479988982 end time Nov-04-09 19:20:07 PST)
1-1/2" rear blocks
Bilstein HD's front
Infinity Sound
www.iamstruth.com
Old 11-10-2009, 09:24 AM   #5 (permalink)
titanup45's Avatar
you can run a 4 channel to the mids and highs. putting the front 2 together wont hurt anything. when using small speakers it doesn't make the ohm load drop like subs do. you will be fine.
Aamp makes a speed cable. It has all 4 speaker wires and a amp turn on ran inside. It is very nice indeed. This is what you will need if you run an amp on your mids and highs. Just cut the wires from the radio and wire em into these wires and run them back to the amp. radio doesnt push them any more but the amp does....hope that answers your ?s
titanup45 is offline   Reply With Quote
Old 11-11-2009, 07:21 AM   #6 (permalink)
It does help answer some of the questions, thanks.
I actually installed the amp over the past several days and it sounds great. I ran new speaker wire to my infinity 6x9's and 6.5' speakers and hooked them up to the amp. I left my infinity tweeters in the dash hooked up to the head unit. It sounds pretty good, but now my door speakers over power my weak 100 watt bazooka bass tube. So, my next step will be to install some subs under the rear seat, and an amp to run those.
Zack
1-1/2" rear blocks
Bilstein HD's front
Infinity Sound
www.iamstruth.com
Help with Sub/Amp install 08.5 w/RF cwbrow2 Titan Visual & Audio Discussion 1 08-05-2008 06:14 PM
Amp Install...need help ToreyC Titan Visual & Audio Discussion 2 12-28-2007 09:19 AM
New Sub & Amp Install! Thanks TECH!!! Blackbeauty Titan Visual & Audio Discussion 15 06-18-2007 01:13 PM
Amp, EQ & Sub install (6 disc stock) Painless Titan Visual & Audio Discussion 4 09-20-2006 08:23 PM
XM && Sony install help schitzo42 Titan Interior Discussion 3 02-03-2005 12:19 PM
