Audio upgrade help, need to pick a brain - Nissan Titan Forum
Old 02-17-2012, 06:44 PM   #1 (permalink)
Banned
JTeeter04's Avatar
iTrader Score: 0 reviews
Exclamation Audio upgrade help, need to pick a brain
Okay i'm going to start this off by saying i dont know a thing when it comes to audio okay so my current set uo right no is just not working so this is what i have to work with:
I have a cheap wiring kit from walmart lol
12" kicker sub in a prefab junk box powered by a kicker mono amp
Kennwood headunit
4 polk audio speaker 200w power tops and i just bought this amp for them Visonik VK1600.4 (vk16004) 4-Channel Car Amplifier
SO my question to you is how do i tie this all together and where to mount and wire and what not?! how do i get power to both amps? do i need a capacitor? where can i mount the amps in my king cab? any and every input helps
JTeeter04 is offline   Reply With Quote
Advertisement
Old 02-20-2012, 09:58 AM   #2 (permalink)
Banned
JTeeter04's Avatar
Re: Audio upgrade help, need to pick a brain
Old 02-20-2012, 10:12 AM   #3 (permalink)
iTrader Score: 1 reviews
Sorry I never posted back on your other thread but, you'll need a distribution block to wire both amps, another set of RCA's, and IMO....a new wiring kit lol
Cst 4" Spindle lift, DR 2.5" Coilovers, 4" Rear Blocks, 5125 Bilstein Rear Shocks, Plastidip'D Grill Mod, 17" Moto Metal W/ 305/70/17 Terras.
jarred3636 is offline   Reply With Quote
Old 02-20-2012, 10:19 AM   #4 (permalink)
Banned
JTeeter04's Avatar
Does that amp look like a good one?
Sent from my Autoguide iPhone app
Old 02-20-2012, 10:21 AM   #5 (permalink)
It might be too strong. If you say your speakers are 200w peak and the amp puts out 200w rms...you'll blow them quick. I have never had a Visonik amp so I don't know if they overrate their products but from what it says, it'll be too strong!
Old 02-21-2012, 09:20 AM   #6 (permalink)
2011PRO4X's Avatar
iTrader Score: 2 reviews
Agrees with what was said above. You should have put your own wire kit together... Those kits (Walmart) are put together with one small amp in mind, most of the time not even that. Your wiring is the backbone of the system, and needs to be good quality and adequately sized. RCA's really need to be good quality as they can make or break the quality of sound. At bare minimum, I would run 4gauge to a fused distribution block, and 8 gauge from block to amps as well as to ground the amps. That is a bare minimum, mind you... I wouldn't go any smaller than that, and that is even pushing the envelope a little.
What kind of head unit are you running? What is the model of the sub amp you have? What is the model of the sub? What is the model of the polks?
As far as the high speakers and the visonik amp are concerned, I wouldn't worry about overpowering the speakers so much. You can take care of that when you tune the amps out... Personally, I would rather overpower speakers than under power them. Also, volume control is a major factor... Are you going for ballz to the wall loud, or good quality sound to make the commutes better? Either way, if the speakers start distorting, turn it down...
About your sub and box. In my opinion, most first time box builders do a better job than a lot of the pre-fabs out there. I have seen pre-fabs actually come apart under heavy bass notes. If you have any wood working skills, we can walk you through building your own box and I think you would be a lot happier in the end. Not only with the sound, but also with the pride of saying "I did that".
2011 Pro 4X
Ebay special CAI (definite powa increase, and 2mpg better)
Grill Mod
Magnaflow muffler
Bully Dog Triple Dog GT
2011PRO4X is offline   Reply With Quote
Old 02-21-2012, 09:50 AM   #7 (permalink)
That1Person's Avatar
Where do you live man? I have a few extra things like nice rca cables and good speaker wire, just laying around, if shipping is cheap enough I can just send it your way, fo free!
Sent from my DROID2 using AutoGuide.com App
06' CC 2wd TITAN
Remote Start
Smoked Tails with LED Reverse
Leer 700 Bed Cover
PD'd Wheels, Fender Flares, Nerf Bars, Front Bumper, Grille, Hood & Badges
K&N Drop In + AirBox Mod
That1Person is offline   Reply With Quote
Old 02-21-2012, 10:26 AM   #8 (permalink)
Banned
JTeeter04's Avatar
I'm in new York, you?
Old 02-21-2012, 08:50 PM   #9 (permalink)
Utah.... a bit far ha. I will check anyways I have a friend that works at UPS, i'll let you know hopefully soon, its a pretty busy week.
06' CC 2wd TITAN
Remote Start
Leer 700 Bed Cover
Old 02-26-2012, 05:22 PM   #10 (permalink)
Gonna chime in on this thread. I have an 08 LE with nav and wanna run an amp and 2 10" subs I have laying around. How do I get behind the head unit? I have done some simple installs (on older vehicles, stuff was simple) but never anything newer. Is it plug and play. Can I get my audio source from the factory sub? Anything would be helpful. Thanks!
bigchad is offline   Reply With Quote
Advertisement
1,100 to upgrade audio tighten06 Titan Visual & Audio Discussion 15 02-08-2012 05:30 PM
Audio Upgrade help sumair Titan Visual & Audio Discussion 1 05-25-2011 12:00 AM
audio upgrade hunter016 Titan Visual & Audio Discussion 5 07-09-2008 02:22 PM
Audio upgrade heyitischris Titan Visual & Audio Discussion 4 04-10-2008 08:04 AM
RF Audio Upgrade and DVD Questions TheKog Titan Interior Discussion 3 07-28-2004 11:58 AM
SEO by vBSEO 3.3.2
