Originally Posted by Shogunles
I am trying to understand what you did. As I am trying to figure out what i am going to do with wiring my 2 headrest monitors to my head unit. You are saying that you used the same power source for the monitors, signal booster, and player (head unit)?
How is that signal booster working out for you? Did you trying wiring the RCA cables without it? I am a bit confused how that component is wired. The way I am seeing it, the video wires from the monitors go to the Video Out and the video wire from the Head Unit goes to Video IN? And then the red and white RCA from the monitors get wired to a split cable and then onto the head units red and white RCA connections? Do I have this right? Thanks
It's not too hard. Each brand might have different color code but it's all basically same.
The monitor itself will have power and ground.
It might have two power, one constant and one switch.
An audio/video input from your dvd player.
Your DVD player same thing. Ground, power (one constant and one IGN)
audio/video out
From your DVD player your video out will go to your monitors
You audio out will go to your head unit
I followed this link to hook my aftermarket dvd player to my OEM headunit
Nissan Armada Forum: Armada & Infiniti QX56 Forums - View Single Post - Stock DVD System Question....
If you're going with an aftermarket head unit with built in dvd player disregard above link.
