I had bought this for a jvc radio that I had in my other car, decided to try hook it up..... works pretty good. BT phone and streaming. Downside is that you need to be in AUX for phone, no auto switching
JVC Mobile Entertainment \ Bluetooth Adapter - KS-BTA100 \ Introduction
hook up power and ground, and plugs into aux port
Bluetooth Profile: The Bluetooth ver. 2.1+EDR certified adapter supports the following Bluetooth profiles.
HFP (Hands-Free Profile)
A2DP (Advanced Audio Distribution Profile)
AVRCP (Audio/Video Remote Control Profile)
Pairing: When you connect a Bluetooth device to your JVC receiver through this adapter for the first time, you must pair the two units. Pairing allows Bluetooth devices to communicate to each other. To pair the two units, you may need to enter the PIN code of your Bluetooth device you want to connect. You can pair up to 8 Bluetooth devices to this adapter. Only one device can be connected and used at any one given time.
Hands-Free Communication: The JVC KS-BTA100 Bluetooth Adapter supports Bluetooth hands-free communication from your Bluetooth mobile phone through your compatible 2011-up JVC head unit . The JVC KS-BTA100 features an integrated microphone and Answer/End button to control your Bluetooth enabled mobile phone. Your phone calls will be heard over your vehicle's speaker system.
Microphone: The KS-BTA100's integrated microphone lets you carry on your side of the conversation as well as voice dial your Bluetooth enabled mobile phone's contacts. Your mobile phone must also support voice dialing for this feature to work. You can adjust the microphone level between - Low, Normal, or High.
Answer/End Button: The KS-BTA100's integrated Answer/End button lets you answer and end phone calls.
Redial: You can redial the last number called or dialed.
Private Mode: The KS-BTA100 lets you switch from Hands-Free mode to Private Mode, so you can talk privately on your mobile phone.
Audio Streaming: The adapter allows your JVC head unit to playback audio wirelessly from your Bluetooth compatible portable audio player or mobile phone. You can use the KS-BTA100's integrated playback controls to operate the following playback options of your Bluetooth compatible portable audio player/mobile phone - Play/Pause, Stop, Fast-Forward/Reverse, and Skip (previous/next).
