Hi everyone. While this may be my first post but I’ve been around reading all yours since I bought my truck back in April 2004.
My first significant mod to the truck is the recent installation of a DVD player with built in TV tuner, two 7” headrest monitors and a 4 input/ 3 output A/V switch (which allows me to watch a different source on each monitor). I bought all of the above Accelevision products as a package deal (that also included the TV antenna, two 2 channel IR headphones and all necessary wiring) from Audioinmotion.com (nice people). The installation may look pretty elementary to some of you but I’m not exactly a whiz kid when it comes to electronics and yet was able to do this install 100% on my own – so if I can do it, you can do it!
The first thing I did was pick up a few pieces of aluminum from the local HD to create a mounting bracket for the AV switch under the seat. Cut it to size, drilled some holes to mount the switch and then mounted the entire assembly to the front and back frame work under the passenger seat. The rear is screwed directly into the back seat brace and the front is attached to the round brace via plastic ties.
Secondly I pulled out the whole glove box and cut a hole in the bottom so that all the rca and power jacks would be accessible underneath and so that the glove box would actually close because the player with rca’s attached was a little too big to fit. Then I just mounted the player using the supplied mounts to the back wall of the glove box, hooked up all the wires and re-installed.
The cool thing about this package is the dvd player came with two power connectors, one to hardwire and one with a cigarette lighter plug – I of course opted with the later. Then I just used one of those inline wire taps to the red cigarette lighter wire to get power to the AV switch, which in turn will also power the monitors. I grounded the switch to the seat frame.
The most nerve racking part was cutting apart my headrests and installing the monitors but after drilling holes in the seat frame and destroying my glove box, I figured I didn’t have much left to loose. For this I just followed the same procedures I found posted on this site and others. Outline, cut an X and cut away a lot of foam. I then passed the connectors out through the existing hole in the headrest for the posts, cut a small hole in the top of the seat, and passed the wire all the way down through and out the bottom back to the a/v switch.
Lastly, took the audio out from the a/v switch and patched it through the Pie amp (purchased separately) then bought a 6’ rca to mini plug adapter from Radio Shack and went right to the aux input. Works like a charm! One day I will have my brother, who is a bit more electronically gifted, hardwire the power and audio connections for me, but for now it was a very simple install. Total time spent was about 8-10 hours (planning time excluded) for a non-experienced person.
I must give props to MacFly, whose set up is what inspired my wife and kids to send me down this road after a few rides in his Armada. Who was I to say no Phase two will include a third monitor in the navigation screen housing, pioneered by MacFly as well. Hope this helps those who are considering this project themselves
you did a good job. I've seen and heard of so called "professionals" that do something not as close as you've done. I'm working on putting 6.2" headrest in mine so I'm going to do some cutting too. Now I'm not as worried.
__________________ My Titan Gallery
2005 Nissan Titan LE 4x4 Smoke w/Big Tow Pkg
305/55/R20 Nitto Terra Grapplers N2 20x9 Rims By MC2 - DF Flowmaster 50 Series Exhaust w/MF Tips - *2 Degree Timing Advance - OEM Bugshield / OEM Step Rails - Utilitrack System w/Bed Extender - Undercover Tonneau HardCover - Westin Chrome Bullbars New Toy - 2008 Super Bee SRT-8 #581 of #1000 - Fully Loaded w/ Option Groups I, II, III - Sunroof - Airbags Front & Side - Remote Start - Best Times 0-60 4.578sec - 1/4mile in 12.9567 Out Of the Box.
Thanks for the kind words guys.
rcantu... you may already know that with the Titan headrests there is no mounting plate only the headrest support bar that makes a loop through the block of foam which makes mounting the headrest tricky. Others have used plastic ties through the monitor's mounting holes and around the bar.
The secret is lots of test fitting as your cutting!
thanks for the tip. I just cut mine this weekend and screwed the mount into the headrest bar. It's on pretty snug. I thought I cut out the outline right but it seems a little crooked. oh well, it's the 1st time.
2. Do you have the RF system and if so, why didn't you hardwire the DVD to the DVD input?
Also, Nice Job!
Titan CC LE 4x4 Sparkle Red Bug Guard and every option except off-road, DVD, Sunroof & Nav.
Add ons: Sliding bed extender, Leer 180 cap, BFG KO's
Just passed the 57,000km mark!
Born on 03/04
Now it is up for sale - or at least the BFGs and the Cap!
Hey keane, thanks. The price for everything mentioned above was $1k even, plus $34 for the pie amp. The kit did not include the RF Modulator - which is fine by me because going throught the aux in is much better sound quality.
As for why I didn't hard wire the audio to the DVD in... well... that's getting a little complicated for me. I do however plan on hard wiring the audio to the aux behind the dash as opposed to plugging it into the existing input on the face of the dash (the way I have it now).
Thanks for the answers. I did see in another thread that there is an easy connection under the overhead console that is for the DVD setting on the RF. You might want to have somebody look for it as you are now freeing up the AUX to use an Ipod while the folks in the rear can watch Shrek!
ok. here's a couple. They are TRC 6.2 inch screens. I was considering 7 but since the buttons were on the right it seemed to wide already.
I left the plastic on the monitors. I'm still working on the system and want to avoid some dust. My wife was watching our wedding video that's why you see our pic in it.
