Go Back   Nissan Titan Forums > Titan Discussion > Titan Visual & Audio Discussion
User Name
Password
best sub box - being discussed at Nissan Titan Forums in the Titan Visual & Audio Discussion section.
Old 06-11-2005, 10:39 AM   #1
bmtitan
Question best sub box
when i have my box built for my truck should i have one long box built
or 2 single boxes and should i have the box sealed and ported. im trying to make this sound good so i need your help. thanks
bmtitan is offline   Reply With Quote
Old 07-06-2008, 12:29 AM   #2
tscharf18
Re: best sub box
if you want good clean sound always use a ported box
and it doesn't matter what shape the box, you just need the recommended airspace and port size that is required of those subs.
tscharf18 is offline   Reply With Quote
Old 07-06-2008, 07:03 AM   #3
TitanBlue
TitanBlue's Avatar
Re: best sub box
Check with tech12volts to get the best built box. He knows all the answers to what you are asking.
Check www.tech12volts.com.
With his prices, I wouldn't be building my own, he really puts out a top quality product and knows the technical end of his job.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 07-06-2008, 05:33 PM   #4
t22a80
t22a80's Avatar
Send a message via AIM to t22a80
Re: best sub box
Unfortunately its much more involved than that. Especially if you are trying to go ported. For the most part ported will get louder but not be as tight and punchy that most people like. The other problem with ported is it requires more airspace to make the subs work properly. This is something the Titan lacks, a lot of space. Ported boxes are much more difficult to build to sound good.
My opinion is a sealed box is better in a Titan. They take up less room and you can have 2 subs instead of 1 that most ported setups will allow.
As mentioned before Tech12volts has built hundreds of these things and knows all sorts of different options based on price and music preference. I'd start there.
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
t22a80 is offline   Reply With Quote
Old 07-06-2008, 06:06 PM   #5
vilim12
vilim12's Avatar
Re: best sub box
yep as others have said, tech12volts shoot him a PM hell set you up
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Stock For Now
vilim12 is online now   Reply With Quote
Old 07-06-2008, 07:44 PM   #6
70DATSUN
70DATSUN's Avatar
Re: best sub box
I'll go along with the get hold of tech12volt crowd on your sub box.
70DATSUN is offline   Reply With Quote
Old 07-07-2008, 03:57 PM   #7
Peytons_Titan08
Peytons_Titan08's Avatar
Re: best sub box
just ordered mine, as far as price, the best around. i called a few local shops just cause i want it now and they cant touch his price. guess im waiting 2 weeks.
2008 Titan XE
Alpine IDA-X001
Polk Audio 6.5" all around.
JL Audio 10W3v3 w/ JL 500/1
K&N CAI
6000k HID's
Sway-A-Way Coilover's, Sway-A-Way Piggy Backs
4" CST Spindle, 4" Rear Block. All from PRG
18" Black XD Monsters wrapped in Terra's 325/65/18
LIFE IS GOOD
Peytons_Titan08 is offline   Reply With Quote
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
