Old 06-17-2005, 10:56 AM   #1 (permalink)
grunge311's Avatar
Xbox in truck
Does anybody have a fix for the horrible noise the xbox brings into the audio system. In my last car as soon as I powered up the xbox you could hear engine loop, now after installing a diff xbox in my truck I get the same results. I have done some searching and everybody agrees the xbox is just noisy.
Has anyone here had any luck getting rid of the noise?
grunge311 is offline   Reply With Quote
Old 06-17-2005, 01:42 PM   #2 (permalink)
I guess it depends upon how the signal is routed to the head unit. Most problems occur when the aux source is grounded to a different location than the main source. The difference in potential can cause noise problems. Connecting a ground wire between the two points can do wonders.
Cheap power inverters don't do much to help the situation.
JLTD is offline   Reply With Quote
Old 06-18-2005, 10:38 AM   #3 (permalink)
BlackBart's Avatar
Won't wireless head phones help this prob?
"Say no to Chrome! And Ugh too Drugs"
BlackBart is offline   Reply With Quote
Old 06-18-2005, 11:02 AM   #4 (permalink)
baseballfanz's Avatar
You are going to hear the same noise in the headphone. As suggested keep all grounding to one spot and also try not to run any RCA next to a power line. These are all points for stereo installation but it might help with game console.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 06-18-2005, 11:21 AM   #5 (permalink)
grunge311's Avatar
Its not the vehicle that does it, I remember when I was trouble shooting this in my car, I plugged the xbox into my garage, and didn't run the engine in the car and still had noise. Just hooking the xbox to my headunits inputs caused the problem.
I wish I still had some links from when I went thru this with my car but I remember the most people thought it was just the xbox has a crappy power supply. There was one guy who bought a new DC PS for his xbox and he claimed the problem went away.
Old 06-18-2005, 01:39 PM   #6 (permalink)
Try here, seems like alot of info on this issue.
http://www.the12volt.com/installbay/...t=Start+Search
Old 06-18-2005, 09:33 PM   #7 (permalink)
raxton's Avatar
my 7 inch screen has built in speakers, no bad noises
04 Titan LE CC 4x4 - Smoked n Loaded
raxton is offline   Reply With Quote
Old 06-20-2005, 08:17 AM   #8 (permalink)
SickWhip's Avatar
Where is you screen mounted?
Old 06-24-2005, 09:28 AM   #9 (permalink)
I Have An Xbox And Play Music And Movies. Sounds Great. No Other Noises.
04 TITAN CC 4x4, 2/4 DROP, 20" DUBS, DEBADGED ALL THE WAY AROUND, STILLEN ROLL PAN, CUSTOM SHAVED TAILGATE, ARMADA PAINTED FRONT AIR DAM, PAINTED MIRRORS, HANDLES, AND WIPER COWL, BRUSHED BILLITT GRILL, CUSTOM 2.5" DUAL EXHAUST, NISMO R-TUNE INTAKE, STILLEN FRONT 14" BIG BRAKES AND MASTER CYLINDER BRACE, TINTED WINDOWS, BLACKOUTS, WINDOW VENTS, LCD, XBOX, CD/MP3 PLAYER, ALPINE TYPE "R" 12 W/500 ALPINE AMP, COMPUSTAR AUTOSTART/ALARM.
life_is_good is offline   Reply With Quote
Old 06-24-2005, 10:11 AM   #10 (permalink)
HitNWakes's Avatar
Same here,
Have 2 xboxes linked together and I have no noise. They run to a A/V switcher though.
HitNWakes is offline   Reply With Quote
Old 06-24-2005, 10:25 AM   #11 (permalink)
grunge311's Avatar
Can you guys who don't have noise try something for me, go to your XBMC, or XBMP, or whatever program your using, and don't play any sound just so your xbox is "idleing" start your engine, close all the doors, crank the volume to max, and rev your engine.
Listen for some noise, if you can't hear it kill your engine and if you can notice a difference.
Are you guys running aftermarket amps? speakers? using ground loop isolators?
Thanks
